[ Total Views: 448 | Total Replies: 0 | Thread Id: 21397 ]
Author: Subject: help needed please
Membersax
Threads: 92
Mood: SAXually Frustrated
posted on April 10th, 2004 at 10:16 PM
help needed please
Hi All,
I've got a strange problem with the distributor on my 70 Beetle.
Tried to check and adjust the timing when I discovered the dizzie is stuck solid in the motor and wont move no matter how loose I make the locknut.
Standard vacuum unit, it's stuck and I cant get any joy.
Tried WD40 and it still wont move in any direction hot or cold.
I'd love some ideas or solution if anybody else has encountered this. Obviously I'd like to get the dizzie out or at least moving without destroying it.
many thanks for any help.
Memberseagull
Threads: 752
posted on April 10th, 2004 at 10:31 PM
ok two ways get a heat gun and warm the case up
or get a blunt peice of steel say 40x 5 flat bar on edge give it a wack with a hammer to ease the case ,this will move it ,dont bash it as you can crack the case .
all above has worked for me :party
Memberlugnuts
A.k.a.: Mike
Threads: 88
Mood: semi-retiring
posted on April 11th, 2004 at 07:57 AM
Im a great believer in leverage theres nothin cant be moved with a big enough lever.Try a piece of steel plate as a base plate and a small crowbar to pry the dissy up,BUT I TAKE NO RESPONSIBILITY WHATSOEVER IF YOU CRACK YOUR CASE :)
