[ Total Views: 724 | Total Replies: 1 | Thread Id: 2277 ]
Author: Subject: Nolathane Mounts
MemberWoozy
Mood: Wahoooooooo!!!!
posted on December 10th, 2002 at 01:14 AM
Nolathane Mounts
I am putting nolathane mounts in place of the crappy rubber ones for the rear mounts on my Baja.
The Box is solid mounted at the front.
Only prob is i do not have any instructions and am unsure how tight to make the bolts holding the mount to the gearbox ?
Anyone know ?
Member70AutoStik
Threads: 18
posted on December 11th, 2002 at 12:03 AM
In lieu of other responses: Normal advice is to use the stock Torque setting - the torque is usually determined by the bolts themselves (specified to keep them within their elastic range.) Increasing the torque may cause the bolts to snap, especially with the increased fatigue produced by the stiffer mounts. New bolts would probably be a good idea, too.
MemberPat
Threads: 31
Mood: Radiant!!!
posted on December 11th, 2002 at 09:54 AM
Or you can use my method: tighten them until they snap, then back-off 1/4 turn.:thumb
But seriously there should be torque settings in a vw manual, or on the net somewhere.
MemberWoozy
smile.gif posted on December 11th, 2002 at 08:48 PM
More Info !!
The mounts i have do not have bolts fixed to them like the standard rubber mounts. If i tighten the bolts past a point the mounts start to deform and the washer seems to start pulling through the mount.
I expect that standard mounts could handle much higher torque as there is some steel involved as well as the rubber.
Also i expect that if you overdid the torque on normal mounts the bolts would tear from the rubber way before they snapped.:alien
MemberGrey 57
A.k.a.: Dean
Old Grey Cruiser
Threads: 355
Mood: (OoVoO) (OVO).
posted on December 11th, 2002 at 08:53 PM
lol good one Pat:D
Member70AutoStik
Threads: 18
posted on December 12th, 2002 at 09:56 PM
Yep, liked that one. But I remember at college watching steel samples snap at far lower stress than it is specified at - a phenomenon known as metal fatigue...
Don't have a solid answer, but if you can get specs on the bolts you use, try tightening them to the low end of the 'elastic' range and go from there. Contrary to a lot of amateur advice, far more problems are caused by over- rather than under- torqued bolts. If they don't come loose and there is no evidence of "slap," they are tight enough.
