[ Total Views: 761 | Total Replies: 13 | Thread Id: 2555 ]
Author: Subject: WOOHOO MY ROTISSERIE WORKS!
Membergeodon
Threads: 63
Mood: stumbling
posted on December 21st, 2002 at 01:15 PM
No more lying on my back welding upside down!!
Memberrustybug
Threads: 4
Mood: (.Y.)
posted on December 21st, 2002 at 01:17 PM
WHAT A TOP JOB.
Excellent work!!!:thumb
MemberKruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
posted on December 21st, 2002 at 01:29 PM
Awesome!!! :thumb So how much do you think it cost you to make?
Kruizin Kol
MemberThe_Bronze.
A.k.a.: Bronze
Minister of Volkswagenism
Threads: 238
Mood: Enlightened.
posted on December 21st, 2002 at 01:45 PM
Here's me salivating in anticipation of the sights of a BBQ - Roast chicken, crackled pork, crispy beef, apple sauce, cold salads, fruit platters, cues of leaking eskys and sauce bottle dotting the table.
Oh well - This looks good too :D.
[size=4]Bronze.[/size]
Membergeodon
Threads: 63
Mood: stumbling
posted on December 21st, 2002 at 02:12 PM
Adding it up.
Steel was about $700. The castors were horrendous- about $70 EACH. I got the professionals to do the welding on the main stuff (eg rotating head) as I wasn't confident of my 170amp mig penetrating 8mm steel but that was free as I was owed a favour or two.
The basic design using heavy plates & bolts to clamp everything together is brilliant because that made it cheap & flexible re were to attach things. The connections at the front were very straightforward:...
Membergeodon
Threads: 63
Mood: stumbling
posted on December 21st, 2002 at 02:16 PM
Rear mounts
......in the rear, I had a choice of the rear apron mounts or giant U-bolts around the rear torsion bar housings. I went for the rear apron but cross braced it to the rear bumper mounts.
Membergeodon
Threads: 63
Mood: stumbling
posted on December 21st, 2002 at 02:24 PM
UP & DOWN
The orig reference (solohobbitt- from this site) used screw jacks from slide on campervans. They cost about $400 each & had a lift capacity of only 500kg and a lift height of only about 400mm. I improvised with 2 1500mm lengths of 24mm allthread. I welded the nut to suit the allthread to a piece of angle & welded that to the lifting piece. The bottom of the allthread pushed on a bucket made with 30mm ID tube filled with washers & grease. A 36mm nut was welded to the top of the all thread & I use an air ratchet to take it up & down
[Edited on 21-12-2002 by geodon]
Membersplitbusaustralia
Threads: 65
posted on December 21st, 2002 at 07:00 PM
That's lookin good george! Scars from falling welding slag do fade after about ten years or so - so they tell me anyway!
RobK
Member11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
posted on December 21st, 2002 at 07:43 PM
Very impressive! Job well done :thumb
Does it turn over completely? It looks as though it only goes as far as you have it in the pics.
I would have been apprehensive the first time i went to rotate it.....nothing like putting a kombi on its lid.......:o
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
Super Moderatorkombi_kid
Good Kid too many projects
Threads: 341
posted on December 21st, 2002 at 07:47 PM
that looks and would work great!!!!!!!! good design!!!!!!!
i like it!
rhys
Membergeodon
Threads: 63
Mood: stumbling
posted on December 22nd, 2002 at 04:42 PM
11cab-360 degrees??
I can lift it higher & it will go 360. But why would you want to?
This way (about 270) I can rest it on one of the rotating crossbeams for stability when working then just swing over if I want to switch sides.
I deliberately left the steering box in with the column attached to remove afterwards- what a breeze removing it when the floor is vertical!
Member11CAB
Threads: 321
Mood: Beach'n
posted on December 23rd, 2002 at 09:08 PM
Doh......should have realised that.
anyway job well done.
Luckily my buggy chassis is easy enough to pick up and rotate by hand. :D
65 Meyers Manx
68 Baja Bug
MemberSKEWtYpe3
Mood: Stiring The Pot
posted on December 26th, 2002 at 02:32 PM
Awesome ! Love it but if it were mine i would still have a few mattresses under neath it.............just in case
(plus i am normally kinda paranoid)
:) Good Job !:bounce
posted on December 26th, 2002 at 07:19 PM
thats the only way to do a Kombi resto... hope the van turns out as good as the work stand...
posted on December 26th, 2002 at 07:30 PM
Ummm....Geodon
Surley you aint gunna do all this work just for ONE kombi resto?
:cussing:bounce:cussing:bounce
Membergeodon
Threads: 63
Mood: stumbling
posted on December 26th, 2002 at 08:39 PM
Meet the ladies in waiting...
I hope to get 1 good bus out of these 2.
Plus Matara's '67 12volt part camper in another shed.
Geez semi-retirement is great!
