| [ Total Views: 435 | Total Replies: 2 | Thread Id: 26740 ] |
Beetle bailey
A.k.a.: Beetle Bailey
Threads: 33
Mood: Hopeful
| posted on August 2nd, 2004 at 07:26 AM |
Strange looking oil
Went to start my trike after fixing some irritating electrical problems which turned out to be a cracked wire & the thing just would not idle.
Opened the oil breather & saw a bad sight. Instead of seeing nothing or a thin film of oil but what i saw was a creamy emulsified lookin mess.
same when I pulled out the dipstick. Any ideas what has happened? I have only just got it back from the mechanic where he replaced a cracked head.
Bu99ed
A.k.a.: Ian Maclachlan
Threads: 10
Mood: Bugged
| posted on August 2nd, 2004 at 08:23 AM |
It sounds like there was water in the oil. It goes like a creamy gundgy gloop. You normally see it around the oil filler cap if it's been raining a
lot. If it's on your dipstick when you pull it out though it sounds like it's in your engine :/ Not sure on the best way to flush it out. Maybe a
few oil changes will clean it or there may be some sort of additive you could put in the oil to clear it. Sorry I can't be of much more help than
that
[Edited on 1-8-2004 by Bu99ed]
oval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
| posted on August 2nd, 2004 at 11:38 AM |
One way to get rid of the water in your oil (provided that no water is still getting into ya oil) is to change the oil with soem fresh stuff, and then
take it for a looong drive - preferably on a freeway. This heats up the oil and 'boils'l out all the impurities (including the moisture) and your
engine will be much happier for it... and you get to go for a nice cruise in ya VW too!
Purple Martin
A.k.a.: Martin
Threads: 141
Mood: warm & fuzzy
| posted on August 2nd, 2004 at 12:45 PM |
I get that stuff (looks like out-of-date mayonnaise) in cold Canberra winters when I've done lots of short trips to work and back. It happens
because the engine never gets hot enough to boil off any water vapour from the air and oil in the case. As oval TOFU said, taking it for a long
drive on a hot day will help. You don't have to worry about water getting into the oil in a VW aircooled motor like you do in watercooled motors
(when mayonnaise can be a sign of a blown head gasket).
1959 red & white Beetle
1975 Kombi camper
Bu99ed
Threads: 10
Mood: Bugged
| posted on August 2nd, 2004 at 02:23 PM |
Mmmmmm mayonaise......
