[ Total Views: 362 | Total Replies: 5 | Thread Id: 27557 ]
Author: Subject: Part of breather pipe cracked?? Help!
Memberjo_tas
A.k.a.: Josie McLean
Threads: 126
Mood: Notchy
posted on August 18th, 2004 at 10:29 PM
Hi, i've got a type 3 notchback (1972) and theres a crack in part of the fuel tank breather pipe.
On my car (not sure if this is original) the pipe is in two pieces, one that comes from the tank up to the inside of the fender, then it connects to another piece that goes through the fender to the filler.
The part that goes through the fender is cracked, or in some way leaking, and its making the car quite fumy.. i can tell by the petrol smelling mud thats coming down in the wheel arch from where the filler is.
What i need to know is, how do i remove this peice, and where can i find a new one? (I'm hoping theres a type 3 expert out there reading this!)
[Edited on 18-8-2004 by jo_tas]
Memberseagull
Threads: 752
posted on August 19th, 2004 at 01:35 AM
and you are what state :alien
MemberOasis
Going alone...
Threads: 77
Mood: Deep
posted on August 19th, 2004 at 02:23 AM
Tasmania... jo_Tas (I'm guessing)
Memberjo_tas
Threads: 126
Mood: Notchy
posted on August 19th, 2004 at 09:38 AM
sorry yes i'm in Tasmania (southern)
MemberPurpleT3
Threads: 55
Mood: knackered
posted on August 19th, 2004 at 10:17 AM
This hose is almost always cracked or broken in some way. FYI it is not a breather it is an overflow pipe.
This is bit you need
http://www2.cip1.com/SearchResults.asp?Search=overflow As you can see it has a built in flange/grommety type of this which fixes it to the inner fender. To remove it you may have to pull the trim off the side of the front boot
If you want an original style part try Vintage veedub or Classic VW in Sydney.
I just used a piece of suitably sized fuel hose from my FLAPS.
Memberjo_tas
Threads: 126
Mood: Notchy
posted on August 19th, 2004 at 10:37 AM
hey, thanks!
although, this doesn't look much like the part thats in it now... but i assume it still fits?
MemberPurpleT3
Threads: 55
Mood: knackered
posted on August 19th, 2004 at 11:05 AM
If it doesn't look like the part shown it's always possible that somebody has already replaced it with something else. From your description of it going through the fender, that's the only part that matches.
The grommet bit can be difficult to pull out of the fender, especially if it has gone hard (like most of them do).
MemberMidlife crisis
Mood: Wornout and Toxic
posted on August 19th, 2004 at 11:51 AM
I did the same I got some fuel hose and the rubber grommet for the hole in the guard has been fine for nearly a year now
[ Queries: 40 ] [ PHP: 2.5% - SQL: 97.5% ]
