[ Total Views: 540 | Total Replies: 13 | Thread Id: 28305 ]
Author: Subject: my fan belt wont go on!!! yay all fixed!!
MemberVw nutter
Threads: 148
Mood: Chillin
smile.gif posted on September 5th, 2004 at 03:30 PM
hey guys i need some help oh how to put on my new fan belt on my 2lt??? i cant seem to loop it around the two pulleys (the big one and the small one), can some one tell me how to put it on?? do i need a speial tool or something??
thanks
[Edited on 8-9-2004 by Vw nutter]
Super Administratorbarls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
posted on September 5th, 2004 at 03:39 PM
there is an adjuster on the alternator but im not 100% sure where cause its been a while since i played with a stock 2L in a kombi. the bolt for the adjuster is above and on the tin ware behind the pulley
the chaos project - click me
MemberVw nutter
Threads: 148
Mood: Chillin
posted on September 5th, 2004 at 04:02 PM
what does this adjuster look like?? im new to 2lters so im a little slow!
maybe send us a pic of what your talking about?
Threads: 296
posted on September 5th, 2004 at 04:18 PM
id love to mate but i drive a bug and even the one with that motor is not the same set up. im working from memory from when i worked with my old man. it is a a allen key head from memory. and it sits in a long slot, you loosen it and the alternator slides to the left so you can get the belt on. to tension the belt lever the alternator to the right
MemberRobo
Threads: 120
Mood: Oval madness
posted on September 5th, 2004 at 05:03 PM
There' a little rectangular plastic cover over the hole in the tinware on the uper right of the alternator. take this out and you will see a allen head set screw. This is the adjuster to slack off the tension so you can move the pulley closer and give you the clearance required.
Rob...:cool:
Boxer Power
Threads: 296
posted on September 5th, 2004 at 05:06 PM
thanks robo i couldnt remember
MemberPurpleT3
Threads: 55
Mood: knackered
posted on September 5th, 2004 at 05:23 PM
Lucky I happen to have a 2L sitting in the garage.
http://members.optusnet.com.au/~steven.cooper/mypic53.JPG
Remove covers and loosen the screw with a 5mm allen key. Push the generator up and left until you can pull the belt off.
[Edited on 5-9-2004 by PurpleT3]
MemberRobo
Threads: 120
Mood: Oval madness
posted on September 5th, 2004 at 05:55 PM
He He
A picture's worth a thousand words!
Rob...:cool:
Boxer Power
MemberVw nutter
Threads: 148
Mood: Chillin
posted on September 5th, 2004 at 06:01 PM
thanks guys
yous rock!!!!:bounce:bounce:bounce
MemberVw nutter
Threads: 148
Mood: Chillin
posted on September 8th, 2004 at 05:29 PM
this is the bolt but it wont move!!:cry
MemberVw nutter
Threads: 148
Mood: Chillin
posted on September 8th, 2004 at 05:31 PM
the bolt undoes but when i try to slide it up or down it doesnt budge. am i missing something??
do i have to take off the tin ware??
Memberkombikim
A.k.a.: Kim
disfunctionally capable
Threads: 84
Mood: always bleary
posted on September 8th, 2004 at 05:34 PM
ok THAT BOLT HAS TO BE LOOSENED A BIT ,
then, have a look at the lower side of alternator & you will see round end of another bolt, at the back end of this, accessable from underneath is a 13mm nut, this has to be loosened also
Threads: 296
posted on September 8th, 2004 at 05:37 PM
had to ask my old man on this one. under the car you have to undo the air deflector plate which has 4 bolts holding it on. once you get this off get a torch and look up there and you will see a 13mm bolt at the bottom of the alternator crack this one off a tad adn you should be able to move the alternator
MemberVw nutter
Threads: 148
Mood: Chillin
posted on September 8th, 2004 at 05:40 PM
ok i will try it now!
thanks
MemberVw nutter
Threads: 148
Mood: Chillin
posted on September 8th, 2004 at 06:02 PM
wooooohoooooooooooo i managed to to it, i needed to use some elbow grease and use a srew driver to lift it up but i got it in the end thanks to you guys, really appreciate it.
thanks again:beer
Threads: 296
posted on September 8th, 2004 at 06:04 PM
not a problem it just one more dub back on the road
[ Queries: 40 ] [ PHP: 2.8% - SQL: 97.2% ]
