[ Total Views: 485 | Total Replies: 2 | Thread Id: 29670 ]
Author: Subject: Wheel bolts stuck?
Member*did*
A.k.a.: Steve
Threads: 0
Mood: happy :)
posted on October 6th, 2004 at 05:57 PM
Wheel bolts stuck?
I had a wheel, with a brake drum bolted to the back of it, not on a car, and the bolts were done up extremely tight.
Normally, if the wheel was on a car then you would just use a breaker bar and some wd40.
But without the wheel on a car it was free to turn around as it pleased, even with me pushing it up against a wall with my knee or foot.
So, I went to the tyre shop and they couldnt get them off with their air tools.
Finally I worked out that all i needed to do was stop the wheel from turning and then i could use the breaker bar.
Solution: Chain the wheel to a tree, in one of the indentations between branches or roots.
After this the wheel could only turn slightly, after which it was stuck and i could apply enough force to get those bolts unstuck.
And the tyre shop said it wasnt possible!
MemberAndy
Andy's Adventures
Threads: 181
Mood: Happy Man
posted on October 6th, 2004 at 11:34 PM
Cool.
A few other tips are to soak the threads with kero, or some penetrating oil for a few days, weeks first.
Also put never seize or similar on the threads before assembly!
Super Administratorbarls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
posted on October 7th, 2004 at 05:12 PM
get some one to put their foot on the brake while you stand on a bit of pipe on the end of a breaker bar with the right size socket on it for the nut
the chaos project - click me
MemberVWFREAK
A.k.a.: Peter / Bones
VWFREAK
Threads: 264
Mood: FREAKY
posted on October 8th, 2004 at 10:47 AM
You got it Barls, well said. I would have advised the same thing.
Member*did*
A.k.a.: Steve
Threads: 0
Mood: happy :)
posted on October 8th, 2004 at 02:45 PM
umm, no... the wheel was not on a car, just loose!
it was a front brake drum that was stuck on, i dont have any beetles with drum brake front ends, so there was no chance of putting it on a car to hold it!
