[ Total Views: 520 | Total Replies: 9 | Thread Id: 31071 ]
Author: Subject: Rusty tank
Super ModeratorBUGBOY
Chief Toy Dude / Head Cruiser
Threads: 403
Mood: A wise German once said
posted on November 4th, 2004 at 07:17 PM
Rusty tank
Ok got a fuel tank that got a dose of water in it and has started rusting.
Was going to chuck some rocks in and shake it around abit to clean it up but any ideas of how to treat it to stop it from starting again?
Everything 36HP !
6-12volt semaphores
Find us on Facebook
Memberjohny rotten
posted on November 4th, 2004 at 07:26 PM
Take it to a Radiator shop for cleaning
Memberdavid
Threads: 157
Mood: amicable
posted on November 4th, 2004 at 08:02 PM
try this
http://www.ppc.au.com/webcontent20.htm
MemberAdam_C
Threads: 164
Mood: could be lower
posted on November 4th, 2004 at 09:53 PM
use chain not rocks, then you can ensure that there is DEFINATELY nothing left in there.... wash with white vinegar and soak it full of the vinegar,, it will strip the rust and wont kill the metal too much....
wash it thuroughly then use a tank sealer :D
Adam
Adzslick@iprimus.com.au
MemberPurpleT3
Threads: 55
Mood: knackered
posted on November 5th, 2004 at 09:28 AM
Like Dave said, if you want to permanently stop it from rusting again, you need to seal the inside. The POR15 Fuel Tank Repair Kit is excellent value and you can do at least two Beetle tanks with one kit. For $100 plus S&H, it's probably cheaper than cleaning at a radiator shop.
Look here http://www.ppc.au.com/category33_1.htm
Memberoval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
posted on November 5th, 2004 at 08:29 PM
Hey Nath, I just bought a POR15 fuel tank sealer for my beetle, and seeing that i will only need half of it, do you wanna go halves? Gimme a u2u if you're interested...
MemberVWFREAK
A.k.a.: Peter / Bones
VWFREAK
Threads: 264
Mood: FREAKY
posted on November 5th, 2004 at 09:02 PM
PurpleT3 hit it right on the head, good call. It's not cheap but worth the $$. Just don't tell the wife.
Member57kombi
Hannover Elder
Threads: 181
posted on November 5th, 2004 at 09:53 PM
Everyone beat me to it.
Go the POR15.
Dave
MemberChe Castro
ankle straps
Threads: 79
Mood: (( }:-{D]
posted on November 7th, 2004 at 10:56 AM
yeah i've used the POR kit, its not cheap but its not that bad. I'd probably prefer to take it somewhere to get properly dipped though, the POR kit doesnt really remove the rust, it just converts it and puts a zinc coating on it.
Jon
MemberAdam_C
Threads: 164
posted on November 7th, 2004 at 11:26 AM
The vinegar will remove the rust and clean the metal.... if you would like to see proof ill get the camera out.... youll have a spotless tank then you can prep it and POR-15 it
Adam
Threads: 403
posted on November 7th, 2004 at 01:15 PM
Ok I`ll give it a go.
Going the rock cleaning method first and then the tank sealer.
Its only a small tank 7lt Its from the spare wheel in my oval.
Nathan
Everything 36HP !
6-12volt semaphores
Find us on Facebook
MemberAdam_C
Threads: 164
posted on November 7th, 2004 at 04:39 PM
use chain not rock, then you can be sure there is nothin in there when you tip it out
Adam
