[ Total Views: 559 | Total Replies: 12 | Thread Id: 32428 ]
Author: Subject: Testing Speedos?
MemberGibbo
Threads: 325
Mood: I Want to Learn Welding!
smile.gif posted on December 2nd, 2004 at 09:18 AM
Testing Speedos?
Morning all!
I dont spose there is a way to test speedos?
I have about 12 to test!
http://img63.imageshack.us/img63/7488/userbar334840xm.gif
MemberVWFREAK
A.k.a.: Peter / Bones
VWFREAK
Threads: 264
Mood: FREAKY
posted on December 2nd, 2004 at 09:22 AM
Ask Dave Birchall or Dave Becker.
MemberMikeM
Buggy Head
Threads: 71
Mood: :duh
posted on December 2nd, 2004 at 10:05 AM
Easiest way I've seen of late is to use a GPS. Most GPSs have a current speed reading. Just compare that to you speedo.
MemberGibbo
Threads: 325
posted on December 2nd, 2004 at 11:44 AM
Erm, I mean that they actually work, not the acuracy.
Do you mean some kinda techy GPS system fitted to a car?
MemberVWFREAK
VWFREAK
Threads: 264
Mood: FREAKY
posted on December 2nd, 2004 at 11:48 AM
I've used my work police radar gun before, but that only works when fitted to the car. I've heard of drills being used, but I'm unsure of the maths behind it. Works in theory I suppose.
MemberMikeM
Buggy Head
Threads: 71
Mood: :duh
posted on December 2nd, 2004 at 11:51 AM
No, just a cheap hand held one in the car with you will do.
Even devices like the "road angel" that use GPS technology have a current speed readout.
as for testing if they work out of the car, yeah spin the shaft and the needle should move :)
MemberGibbo
Threads: 325
posted on December 2nd, 2004 at 11:53 AM
Thanks all.
Super ModeratorYogie
Threads: 108
posted on December 2nd, 2004 at 12:36 PM
Lionel Otto instruments in Evans Road Salisbury test them. Not sure how much it costs but we just had 2 beetle speedos rebuilt and had one of them converted to kmh for $160 if that helps. ( We got the kmh face plate from an L bug to fit on to the older speedo and he recalibrated it)
Yogie
MemberGibbo
Threads: 325
posted on December 2nd, 2004 at 12:38 PM
Excellent info, thats just around the corner from me.
Cheers!
MemberGibbo
Threads: 325
posted on December 2nd, 2004 at 12:57 PM
A very kind person just U2U'd me this info, thanks!
Hi when I tested my speedo I had a small nylon tool used for adjusting t.v's , filed down the end to fit in where the cable goes and used a drill ( running backwards from memory), to turn it. and if it sqeals the internal gears need lubrication.
posted on December 2nd, 2004 at 01:52 PM
If you just want to see them spin the needle get a battery drill n old cable hook them up and spin the drill in reverse.... easy
Memberblutopless2
DAMSLO
Threads: 187
posted on December 5th, 2004 at 05:32 PM
should be able to test the accuracy with the drill also.. if you know how fast the drill is running then you can calculate the reading on the speedo.. should have the conversion on the speedo - usually stamped on the back.
1974 1300
1997 MK3 Golf GL
2003 NB Cabrio
2012 Golf VI GTI
2014 Audi A4 Quattro
Memberjonno-t3
A.k.a.: johnathon cooper
Mood: stewed
posted on December 6th, 2004 at 05:47 PM
yeh...as vw54 said...in the drill and wack it in reverse....my dewalt 12v does about 70km/h!!!
jonno
"if only everything in life was made like a volkswagen"
http://forums.aussieveedubbers.com/banner/avdbanner39.gif
[ Queries: 40 ] [ PHP: 2.5% - SQL: 97.5% ]
