[ Total Views: 501 | Total Replies: 9 | Thread Id: 33496 ]
Author: Subject: help, my sisters bug is driving funny, clutch maybe?
MemberVWFOOL
Threads: 572
Mood: inspired yet?
posted on December 30th, 2004 at 10:43 AM
hi
my sisters got a 1960 beetle, not sure of the gbox, probably a 1300 swing axle. yesterday just starting driving badly, she says its shuddering wen u take off really badly, and now wont go into second, or popping out of second and also not going into fourth. i havent had a chance to drive it yet.
could this b a clutch problem or a gbox problem maybe?
any help is appreciated
thanks
sam
One man's junk...
Membersax
Threads: 92
Mood: SAXually Frustrated
posted on December 30th, 2004 at 02:25 PM
Gearbox mounts maybe?
" You're not a team player "
MemberVWFOOL
Threads: 572
Mood: inspired yet?
posted on December 30th, 2004 at 07:32 PM
bump
One man's junk...
MemberLuftkühlte
Threads: 1
Mood: adrenal overload
posted on December 30th, 2004 at 07:42 PM
bring it around, can have a look, could be a few things, hard part is parts.. no local stores open this time of year.. if it is gearbox mounts.. can fix it.. Dad has 1 or 2 lying around
MemberChewy
Threads: 75
Mood: Buggered
posted on December 30th, 2004 at 07:58 PM
Sounds like it would be the front G/B mount.
MemberVWFOOL
Threads: 572
Mood: inspired yet?
posted on December 30th, 2004 at 08:03 PM
so this mount will affect gearchanges etc? sounds like the whole thing is shuddering violently and gear changes r bad. wats ur number martin, im on msn or u2u me, thanks mate...
One man's junk...
posted on December 30th, 2004 at 08:59 PM
Sounds like it may be a lot of things...
shuddering clutch can be oil on clutch plate...
also engine/gearbox mounts are split in half....
and gearlinkage may be a bit sloppy....
Hopefully its the gearbox/engine mounts....
You can get NOLATHANE ones that virtually last forever....
they are red in color....
Best of Luck... but its not the end of the world....
MemberVWFOOL
Threads: 572
Mood: inspired yet?
posted on December 30th, 2004 at 09:12 PM
cool she is freaking out, she just spent $500 on the car getting it driving well and this happens, first car, P plater, u know hwo it is...
One man's junk...
MemberLuftkühlte
Threads: 1
posted on January 5th, 2005 at 04:15 PM
its the front gbox mount :( and a very dodgy selector linkage.. trying to locate parts now
Memberkarmen
Threads: 130
posted on January 5th, 2005 at 10:44 PM
if all fails u guys muss not overlook the clutch cable conduit above the box
ie in 60s and pre- (split case) - often the bracket gets fatigued and cracks and reduces the important "S" bend tention for the clutch.
later than 60's have a more substantial bracket but poor front mounts will reduce the tension and produce severe shudder on take-off etc
you may need to add washers to increase tension esp if you have a different ( later ) box in it...
Karmen
56 oval resto 60 Cal KG
63 Baja 80 GLD parting
