| [ Total Views: 977 | Total Replies: 7 | Thread Id: 33953 ] |
kombibob
Threads: 173
Mood: at by cows
| posted on January 10th, 2005 at 05:03 PM |
straight axel wheel/brakes?
Hi all just got my bus back from getting a straight axel convertion thanks to Brad and the gang from custom off road great job.
Just wondering what most people do for the new spring plate clearance, plates or change the wheel offset as i want to put my old wide 5"s back on
the drums are just 70 1500 L bug but i have some wide 5's for when i get it sorted.
thanks
| Error |
1961 swb buggy
1960 karmann ghia
2012 Skoda Octavia scout
Get down low and go,go,go
57kombi
Hannover Elder
Threads: 181
| posted on January 10th, 2005 at 08:42 PM |
See if you can find some wide 5 type 3 brakes and backing plates, thats what I fitted to mine.
I also found that I could only fit beetle wheels(solid wide 5's ) to allow enough clearance.
Dave
t2
stop taking life so serious
Threads: 206
Mood: tired
| posted on January 10th, 2005 at 09:02 PM |
yep i got some type 3 wide 5 drums on the rear aswell.
bus looks sweet as what size tyres you got on the front they look nice , i have 195/50/15s on mine and i have the adjusters fully down and the gap is
alittle big between the wheel and wheel arch yours look sweet. i think i will be doing a narrowing job and adding some drop spindles to mine after i
finally get rego again |
kombibob
Threads: 173
Mood: at by cows
| posted on January 10th, 2005 at 09:10 PM |
thanks
i have 195 65 14s on the front but i think i will put them on the rear when i get it sorted and put 185 60s on the front and drop her down some
more
i was suprised how nice she rides after the drop with just the adjusters
1961 swb buggy
1960 karmann ghia
kombibob
Threads: 173
Mood: at by cows
| posted on January 10th, 2005 at 09:32 PM |
Hey Darren did you have change the offset to fit your rear wheels?
1961 swb buggy
1960 karmann ghia
BenettonVW
AVD Forum Founder
Threads: 185
| posted on January 15th, 2005 at 08:33 AM |
There is also a wide range of aftermarket spring plates available. Some 'notched', some adjustable, and I also found some recently with a dogleg in
them so maybe you don't have to shorten the axles.. I dunno.. gotta find the pic again..
robnjo
Threads: 254
Mood: its tricky tricky tricky
| posted on January 15th, 2005 at 08:37 PM |
Man that looks awesome... hmmm, so brad did this, mmmm.....kool
Brad
Threads: 332
Mood: Manx Buggy Building
| posted on January 31st, 2005 at 10:01 AM |
mmm maybe
The problem Bob has isn't ride height it is that he has custom 14" rims ATM. With the narrowed rear track that the Straight AXle Conversion gives
they no longer fit.
When you do a Straight Axle Conversion to thing that stops you going lower is actually the top of the front guards. I have set it up so they clear on
full up travel, but only by about 10 mm. Lower profile tyres will allow it to go even further down into the weeds...
I must say it does look pretty cool sitting next to the Baja Bus ... one xtreme to the other ....
