| [ Total Views: 734 | Total Replies: 13 | Thread Id: 34393 ] |
Dannyboy
half man , half horse
Threads: 357
Mood: about 2" off the floor
| posted on January 20th, 2005 at 08:02 AM |
61 Beetle steering
My new 61 has massive amounts of play in the steering. I take it that the steering box is caput! Do i go for a rebuild or just replace. Cheapest
option needed.
Dan
The Lower Class
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
| posted on January 20th, 2005 at 08:35 AM |
Cheapest option is to turn the adjusting screw in a bit, but not too far as the box will get hard to turn.
If it still has heaps of play and grabs every now and then as you turn it, then it is well and truly stuffed.
Dannyboy
Threads: 357
| posted on January 20th, 2005 at 08:46 AM |
Matt it has about 1/3 of a turn of steering wheel before wheels start to move.
Dan
The Lower Class
Chewy
Threads: 75
Mood: Buggered
| posted on January 20th, 2005 at 09:03 AM |
Check all other steering components first.
It could just be a tie-rod end.
Che Castro
ankle straps
Threads: 79
Mood: (( }:-{D]
| posted on January 20th, 2005 at 11:04 AM |
phoar 1/3 of a turn, i thoughy my '63 was sloppy, moves about an inch in rotation.
Check that the steering box is adjusted, if not get a new one (about $250). Make sure its tightened properly as well. and like chewy said check the
tie rod ends are good. Also check the king & link pins are good.
Jon
VWCOOL
Threads: 235
Mood: happy to help
| posted on January 20th, 2005 at 11:06 AM |
Check the rubber doughnut, too - it will allow a lot of 'slack' if it is stuffed. It might also kill you
Pay your debts, CxxT
Dannyboy
Threads: 357
| posted on January 20th, 2005 at 10:00 PM |
Mmm manual required i think. The screw , is it easily visable and how do you know when it;s adjusted??
First of many Q's but i'll check all of the above
Many thanks dan
[Edited on 20-1-2005 by dannyboy67]
The Lower Class
jo_tas
A.k.a.: Josie McLean
Threads: 126
Mood: Notchy
| posted on January 20th, 2005 at 10:51 PM |
On my old beetle ('69) when you took out the spare wheel there was a couple of little plates behind it you could remove.. one of them, when you took
it off, gave you full view of the screw and locknut thing
twoguns
simply aircooled
Threads: 226
Mood: simply cruizin'
| posted on January 21st, 2005 at 10:03 AM |
dan, let me know how you go,a s ive been playing with my new beam, and now i have to same play as you???
Simply Cruzin'...
Dannyboy
Threads: 357
| posted on January 21st, 2005 at 11:53 PM |
I'm having a look Sunday arvo Twoguns. See if its anything obvious etc. mine has about 2-3 "'s of play before wheels turn. Crazy to steer!
Dan
The Lower Class
twoguns
simply aircooled
Threads: 226
| posted on January 22nd, 2005 at 04:18 PM |
keep me posted. i am having another look next week. but mine is easy half turn each way!!!
Simply Cruzin'...
Dannyboy
Threads: 357
| posted on January 23rd, 2005 at 06:15 PM |
Two guns i have exactly a 1/4 turn of the wheel. Jacked it up , only had a quick look but tie rod ends seem new(ish) and okay, rubber donut on
steering a little worn but in one piece and box was covered in shite so i gave up for today! Job for the week! I hear a Corona calling!!
Dan :P
The Lower Class
twoguns
simply aircooled
Threads: 226
| posted on January 23rd, 2005 at 07:30 PM |
hahahha... htats how i felt. have it onthe board to look at again, next thursday or friday...
47yrs of build up certainly adds to the job at hand!
[Edited on 23/1/2005 by twoguns]
Simply Cruzin'...
twoguns
simply aircooled
Threads: 226
| posted on January 28th, 2005 at 08:29 AM |
hey dannyboy... found my prob i think. my woosie little girly arms! no seriously i dont think i tightened the steering box on the beam too well and
the arm that comes off the base seem to have some movement. tightened both and, whallah!
now to play wround some more withthe rear and i should be right. hope you sort yours.
2G.... cruisn' today:bounce
Simply Cruzin'...
