[ Total Views: 389 | Total Replies: 2 | Thread Id: 34458 ]
Author: Subject: steering help needed.
Membertwoguns
simply aircooled
Threads: 226
Mood: simply cruizin'
posted on January 21st, 2005 at 10:00 AM
he all am hoping to get some advice and help. have been playing with 'squidwood'... refer to attached pic. anyway i cant seem to sort the play in the steering. was finish before.
anybody got any tips or things to look for?
the beam is a narrowed 2in and adjusters fitted. all i hvae done is loosen the steering box and swapped the beam.
jsut seems a lot of play and wobble.
also could it be that the steering shaft can still work, albeit a little vague if its not positioned right?
Simply Cruzin'...
Member56astro
Threads: 74
posted on January 21st, 2005 at 10:50 AM
When I replaced the beam in mine a week or so ago, I was under the front swinging off the tie rods to try and centre the pitman arm and adjust the stops. I noticed there was some play somewhere so as I fiddled I found that where the pitman arm fitted to the splined shaft from the box, there was some play. Just had to tighten the clamp and voila!
Nice looking dub BTW
35MPG on 101.3kPa
Membertwoguns
simply aircooled
Threads: 226
posted on January 21st, 2005 at 11:00 AM
thanx. will have a look at that, but i think its tight.
Simply Cruzin'...
