[ Total Views: 501 | Total Replies: 2 | Thread Id: 34485 ]
Author: Subject: Tuning links and advice.
MemberThe_Bronze.
A.k.a.: Bronze
Minister of Volkswagenism
Threads: 238
Mood: Enlightened.
posted on January 21st, 2005 at 08:47 PM
I'm up to tuning me Baja. I think it needs it since it's only running on the two cylingers on the left hand side. Driverside manifold is stone cold even after 3 mins idling.
Anyhow - want to go right over it and get it up to scratch. I'd take it to the mechanic but that's what I did and now it runs worse than before it went. At least the brakes are A1! (I hope).
I found this: http://www.aircooled.net/gnrlsite/resource/articles/jetting.htm
and this:
http://www.geocities.com/MotorCity/Lane/1970/tuneuplinks.html
on the forum. If you have any other handly links and suggestions I'm willing to listen.
The Bronze.
[size=4]Bronze.[/size]
posted on January 23rd, 2005 at 05:28 PM
Bronze
this is the best one by far
http://www.geocities.com/aussiebug1970/
Rob (Aussiebug???) use to post here regularly - but he got a job that took him 24/7.
I have emailed him a few times and he answers - just too busy to post.
Hi Rob! - if you are reading
Anyway - he must still be active as he redirected his site a fe months ago
Should talk to whoever and get it "sticky" on the Frequent Questions section
Barry
MemberThe_Bronze.
A.k.a.: Bronze
Threads: 238
Mood: Enlightened.
posted on January 24th, 2005 at 09:04 AM
Thanks Barry - I knew there were a few good links around. I did a quick seach and found those two. Thought they would be good together with any others people had to add.
My battery is cactus so I don't think I can go the whole way without replacing that first. Will do the valves today and lube, check the dizzy. Bit of moisture in it unfortunately. These sites are a great read and the tuning of the PICT 34 was a gold mine for me.
Yes I remember Aussiebug - met him once to I think at the Nationals a couple of years ago to I think. Will have a look at th at link. I printed the other two off and stored then in plastic folders as I think there will be a few occasions I can refer back to them.
This is the redirect: http://www.vw-resource.com/
Bronze.
[Edited on 23-1-2005 by The_Bronze.]
