| [ Total Views: 664 | Total Replies: 5 | Thread Id: 34770 ] |
dodge
Threads: 82
Mood: dubbing
| posted on January 29th, 2005 at 12:38 PM |
dirty engine
ah qvestions, qvestions and more of them! haha
when i first purchased my kombi roughly 3 yrs ago (its a 1973 model) i had to degrease my engine coz there was oil all over it.
i had a look the other day and its all back!
i'm not real sure if this is a problem. just wondering if this is normal for kombi's or VW's to have oil and grease all over the engine (ie when
you crawl under the car, there is grease everywhere - not in the engine compartment when you open the engine door).
should i degrease again? or is this normal?
or do i have a leak somewhere? (I don't go thru that much oil, so i didn't think it was a problem. i go thru a fair amount of fuel tho)
thanks peoples! |
VWCOOL
Threads: 235
Mood: happy to help
| posted on January 29th, 2005 at 01:07 PM |
A little bit of weeping is kinda acceptable... but excess may mean your rear main crank seal is leaking, or the oil cooler is leaking (usually because
the seals between it and the engien case are perished) Degreas and see if you can track down the leak
too much grease can lead to higher oil temps - by insulating the engien case
Pay your debts, CxxT
Robo
Threads: 120
Mood: Oval madness
| posted on January 29th, 2005 at 05:30 PM |
Keep it clean man! It will love you for it, if its dirty it cant cool properly. I clean mine at least once a month, I make sure there is no gunk at
all on it. A clean motor is a happy motor!
Rob...
Boxer Power
MUD BASHING ANYONE ??
Threads: 23
Mood: Need to be inspired !!
| posted on January 29th, 2005 at 09:11 PM |
Perfect ansewers dudes dead on keep em clean then you can track it down and it run nice and cool
You only need two tools
Wd40 if it don't move and it should
Duct tape if it move's and it shouldn't
twoguns
simply aircooled
Threads: 226
Mood: simply cruizin'
| posted on January 29th, 2005 at 09:20 PM |
some times you get excess blowing out from the over flow or breather. i have gotten a filter and put on the breather to keep the mist down. otherwise
you get a fine coverage everywhere. but mines T1 so i dont know about mounting on yours.
how is your bus anyway, did you sort your prob?
Simply Cruzin'...
waltermitty
Mood: Hungry for mor
| posted on January 30th, 2005 at 08:16 PM |
Keep it klean ! Thats what mum always told me Nehow!Mitcl
23 windows ...8 too many!
