| [ Total Views: 440 | Total Replies: 4 | Thread Id: 34843 ] |
Dannyboy
half man , half horse
Threads: 357
Mood: about 2" off the floor
| posted on January 30th, 2005 at 09:25 PM |
Notchback rear engine mount.
On my notch motor there is a rear mount that bolts up to the body. It's like a donut that slips over the mount and then bolts up to the body. Should
the mount be tight ( rubber donut ) around the part of the engine that locates in it. I have had a look and i don't see much wear on it and don't
think that i'm missing any parts , nothing left in the parts bin.
Thank you
Dan
The Lower Class
Stanley
Threads: 270
| posted on January 31st, 2005 at 06:36 AM |
I'm pretty sure it should have no movement up or down but will have some movement other than that. I think its more of a support than anything.
kombi_kid
Good Kid too many projects
Threads: 341
| posted on January 31st, 2005 at 08:44 AM |
it will have some movement what u will find is that there is metal shims under where it bolts to the chassis and i think its meant to be centralised
by this im not sure just a guess but look in the manual i would say!!
but definately have some movement just more of a support for the engine !
rhys
Dannyboy
Threads: 357
| posted on January 31st, 2005 at 04:28 PM |
Mmmm , i'll take a pic and get back to you. Cheers Guys Dan
The Lower Class
1303Steve
| posted on January 31st, 2005 at 09:28 PM |
Hi Danny
If you look what the cylinder parts is held (8mm bolt in die cast alloy) on by you realise that they cant do very much. Just get to be snug without
any preload.
