| [ Total Views: 490 | Total Replies: 5 | Thread Id: 34895 ] |
shamer11
Threads: 8
| posted on January 31st, 2005 at 10:36 PM |
Indicators
I have just had a bit of an overhaul of my 74 Kombie, one of the things while driving from the garage home I noticed is when indicating right the
indicator freezes (stops) , left is fine (constant as usual) I have since found out that it does it when I have my foot on the break any ideas what
the hell this is and how to fix this problem.
Any ideas guys?
Stevie Boy!!!
karmen
Threads: 130
| posted on January 31st, 2005 at 11:32 PM |
check poor earth
and also corroded connections
incl those in the fuse box and the lights and the juction boxes
remmeber these things are getting olde !!
Karmen
56 oval resto 60 Cal KG
63 Baja 80 GLD parting
shamer11
Threads: 8
| posted on February 1st, 2005 at 12:00 AM |
Where do I find all that then?
SB!!!
shamer11
Threads: 8
| posted on February 1st, 2005 at 12:01 AM |
Thanks BTW
All help most welcome
SB!!!
Bungawatta
Mood: Zekkocho
| posted on February 1st, 2005 at 12:22 AM |
I'd be happy to give you a hand, not that I'm confident to fix the problem but I can help.
Where about are you in Brisbane? Or can you come around near UQ?
ratty 63
A.k.a.: Rossco
Threads: 74
Mood: Just cured my shed envy!
| posted on February 1st, 2005 at 12:42 AM |
If its only happening when the brakes are on, then it is most likely that it will be a bad earth on the taillight housing on the side of the problem.
Remove all the screws from the earth wire (brown wire in earlier cars - not sure of color in your car though, but will still be under a screw that is
attached to the body close-by) and clean the connections before replacing the screw.
R
