[ Total Views: 1433 | Total Replies: 12 | Thread Id: 35894 ]
Author: Subject: kombi accelerator linkage help needed - now sorted
Membertype3lover
A.k.a.: The Smashed Repairer
in the garage...
Threads: 90
Mood: stoked
posted on March 8th, 2005 at 09:40 AM
Hi all,
My '76 camper has snapped off the gas pedal pivot bracket from the floor due to worn linkages putting the pedal on an angle for some time. Can anyone suggest a fix for this and where I could get 2nd hand parts or a repair kit in Sydney? The pivot pin has also broken.
I thought of drilling out a bracket from another kombi and riveting it to the floor but not sure if rivets will be strong enough to keep it there.
Cheers!
Toby
[Edited on 25-3-2005 by type3lover]
MembermnsKmobi
Threads: 27
posted on March 8th, 2005 at 10:16 AM
My 76 camper had the same problem and was fixed by a PO by welding an ordinary door/cupboard type hinge to the pedal and bolting it to the floor. Works a treat!
Membertype3lover
in the garage...
Threads: 90
Mood: stoked
posted on March 9th, 2005 at 03:59 PM
Thanks mate.
With a good strong hinge that would be an effective fix I guess. No to sound like a purist but if I could get the original bits in good order that would be preferable. I am warming to your idea though.
BTW I had been driving around like this since I bought the car (3 weeks ago) with it getting progressively worse until I decided to remove it and take a look. Now I just wear thick shoes and push hard directly on the rod instead. :jesus
I was thinking that kombi's were real slugs to drive. That was before I discovered that I was only getting maybe 1/2 throttle with the pedal flat to the floor!
Cheers!
Toby
MemberAndy
Andy's Adventures
Threads: 181
Mood: Happy Man
posted on March 9th, 2005 at 04:30 PM
I'm not sure new parts are available.
I scavanged a good used piece of floor from a wreck for mine. The hing is quite simple and would not be hard to make your own factory looking copy.
MemberVolksFolks
A.k.a.: Pandy
Threads: 350
Mood: Proud DSK Contributor
posted on March 9th, 2005 at 04:35 PM
Hey, this repair part is available from here >>>> http://www2.cip1.com/?Click=38510  Enjoy
Andy
Membertype3lover
in the garage...
Threads: 90
Mood: stoked
posted on March 9th, 2005 at 06:49 PM
VolksFolks, I looked but didn't see the part on their website.
[Edited on 10-3-2005 by type3lover]
MemberKruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
posted on March 10th, 2005 at 12:57 PM
I too used a std door hinge...
Kruizin Kol
MemberMickH
A.k.a.: Michael Hutchinson
Hairy Gutted Sloth
Threads: 29
posted on March 10th, 2005 at 01:28 PM
I used a small gate hinge and bolted it to the floor after bolting the pedal to it. No more problems:o
tssnq.com.au
MemberVolksFolks
A.k.a.: Pandy
Threads: 350
posted on March 10th, 2005 at 02:38 PM
Sorry, try again go here http://www2.cip1.com/?Click=38510  and then copy and paste this to the search box
VWC-211-798-507-A -
Andy
Member57kombi
Hannover Elder
Threads: 181
posted on March 10th, 2005 at 03:11 PM
New parts are available from Classic VW(pacific) in Brisbane.
They get them from Justkampers in the U.K.
They can also get the whole assembly or just the parts, to fit Right Hand Drive cars.
Dave
Membertype3lover
in the garage...
Threads: 90
Mood: stoked
posted on March 10th, 2005 at 04:01 PM
Wow thanks for all the replies!
I found the product on the CIP website but they want more for shipping than the cost of the part!
Might be time to call a few wreckers or go to the hardware store and get a hinge. The linkage under the pedal in my bus is pretty sloppy so will the hinge be good enough to compensate? Will shimming it up with washers alter the geometry and pressure needed to push the pedal all the way?
Also, there is a small return spring under there which is broken. Do I need it or will the throttle springs down the back provide enough return without it?
Thanks for all the help.
Toby
Member57kombi
Hannover Elder
Threads: 181
posted on March 10th, 2005 at 04:33 PM
Contact Roy at Classic he will sort you out.
Call 0421 765 600
Membertype3lover
in the garage...
Threads: 90
Mood: stoked
posted on March 25th, 2005 at 03:52 PM
Thanks fellas,
I've just done the gate hinge "mod" and I must say it really works a treat!
Much stronger than the original design for sure.
Couldn't wait for the real thing (thanks anyway Roy from Classic VW Pacific!) because I need to drive to the Blue Mountains tomorrow and pressing on the rod without a pedal there has given me somewhat of a sore foot!
Anyway that's another winner from those in the know.
I'll be sure to buy you guys a beer when we catch up someday... :beer
Thanks heaps!
Toby
