[ Total Views: 554 | Total Replies: 8 | Thread Id: 36693 ]
Author: Subject: replacing ball joints
Super Moderatorkombi_kid
Good Kid too many projects
Threads: 341
posted on March 23rd, 2005 at 03:55 PM
hey people
do many people here replace there own balljoints or is it too much of a pain in the arse??
rhys
Member56astro
Threads: 74
posted on March 23rd, 2005 at 03:57 PM
I did all mine Rhys
There's a bit of muckin around getting the old ones out, but replacing them is a breeze.
35MPG on 101.3kPa
MemberMikeM
Buggy Head
Threads: 71
Mood: :duh
posted on March 23rd, 2005 at 03:58 PM
It's not hard if you have a press.
And this is the easiest method of removal:
http://www.1800vw.bizhosting.com/qa_balljointrem.htm
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on March 23rd, 2005 at 04:13 PM
I looked into this for our bus and it was much easier and more cost effective to get a wokshop to do them. I do nearly everything else myself, but the balljoints and gearbox's are best left to those with the right tools in my opinion.
posted on March 23rd, 2005 at 04:50 PM
If your doing a Beetle then they can be done on the car.....
However if your doing a Kombi... then u need to remove the trailing arms brakes etc etc and use a 25 ton press to push the buggars out..... they WILL NOT come out any other way.
And if your doing them replace all 4 at the same time so you only have to get one wheel and camber alignment. Also check the tie rod ends and do at the same time ,... less expense on the wheel aligner
smile.gif posted on March 23rd, 2005 at 07:02 PM
I took My arms to the local mechanic who tried to push the originals out with a 10 tonne press..... and they wouldn't budge....
He had to take them to a 25 tonne press to push them out..
So, I wouldn't have had any chance of doing it at home....
I would take them to a Mechanic or someone with a 25 + tonne press to do the job....
Has anyone drilled out the new non greaseable ball joints and inserted grease nipples in them???
I do believe it would be worth it in the long run....
My original ball joints were in good condition - no movement at all - only the rubber boots had splits in them...
They had been greased regularly with Lithium based Moly grease.....
I suppose what I should have done, is bought 4 cheap ball joints and used the rubber boots off them....
but I didn't.... I tried to buy rubber boots without success...
Threads: 341
posted on March 27th, 2005 at 09:01 PM
kool guys might aswell try it myself!!!
rhys
biggrin.gif posted on March 27th, 2005 at 09:17 PM
It may depend on whether they were ever replaced before..
as the originals are really pressing in....
Mine were totally destroyed while being pressed out....
well 25 tonnes does make an impression....
You might Be lucky.... simple to take the arms to someone if You can't do it..... and doesn't take long to press them out..
so shouldn't be expensive...
MemberMickH
A.k.a.: Michael Hutchinson
Hairy Gutted Sloth
Threads: 29
posted on March 27th, 2005 at 09:31 PM
Very easy to do in a beetle...just buy a balljoint remover tool(supercheap etc) for around $15 and do it yourself. The lower joints on a Kombi are best left to some large hairy guy with the right tools:duh
tssnq.com.au
