[ Total Views: 486 | Total Replies: 1 | Thread Id: 37566 ]
Author: Subject:
MemberVWCOOL
Threads: 235
Mood: happy to help
posted on April 13th, 2005 at 11:09 AM
Originally posted by lucylawless
hi now u have to explain in woman terms.
im trying to take of the diagonal arm of my vw Lbug 74.
i got all the bollts out etc.
but now as a look towards the end of the diagonal arm where the rubber bush is its got me puzzled on how to get the rest off.
im doing this right now so any help thats fast would be brilliant thankyou
I use a small length of hex-shaped steel (like an allen key) with a socket on the end.
Pay your debts, CxxT
MemberBiX
Threads: 154
posted on April 13th, 2005 at 11:36 AM
ok well you need a 17mm (or was it 14mm?) allen key or allen key socket drive. Its the same size as the oil plugs in the gear box. you can get these like a socket for your ratchet drives. about 15 dollars at a proper tool place, not your super cheap or simialr.
unbolt this and take the bolt/pin completely out, then the arm will jsut fall out.
Go hard or go home!!!!
