| [ Total Views: 545 | Total Replies: 13 | Thread Id: 37906 ] |
battybat
Threads: 29
Mood: selling up & moving out
| posted on April 19th, 2005 at 05:17 PM |
need pix of beetle rear suspension!
anyone got any pix of the rear suspension of a 69 swing axle beetle - particularly the bump stop mounts and the other thingy on the swing arm
buggered if I can find any pics anywhere, and neither of my manuals has a pic for the swing arm versions
doesn't matter if it's on the car - looking for clues as to how it all goes back together - didn't realise I had to take my own pics when I took it
apart!!
Terry
http://www.dtsband.com - Rock and Roll is NOT dead
My other car is a scooter, and it's in even more bits than my beetle. One day they will both be back together.......
Chewy
Threads: 75
Mood: Buggered
| posted on April 19th, 2005 at 05:35 PM |
heres a pic of my 66
dunno if that helps??
what do you need to know?
The bump stops mount to the upper springplate/axle tube bolt.
The nuts are on the inside when you put them together (otherwise bolts heads hit shocks)
battybat
Threads: 29
| posted on April 20th, 2005 at 03:52 PM |
thanks!
confirms where the bump stops go
terry
battybat
Threads: 29
| posted on April 20th, 2005 at 06:34 PM |
and what the #*!^ are these for!
can't believe I'm asking this! any ideas what these bits are for, and where they go (boy do I wish I'd taken some pics BEFORE I ripped it
apart!!)
I'm assuming they go somewhere on the rear suspension, looks like they fit round the swing axles?
Terry
| Error |
battybat
Threads: 29
and another pic of the same mystery bits
| Error |
battybat
Threads: 29
| posted on April 20th, 2005 at 06:38 PM |
my floorpan
replaced the right hand rear quarter, patched the front left footwell and made a new section for the left front rail
a coat of rust killer, then a couple of coats of flat black rust cure paint (after a shitload of wire brushing, sanding and grinding) and it's nice
and solid again!!
wish I could say the same for the body
| Error |
Jeza
Threads: 23
Mood: Spinning
| posted on April 21st, 2005 at 07:28 AM |
Can't remember how they fit, but they are the "Z-bar" pieces that fit to the swing arms. The uprights go through them and connect to the bar that
goes across the top of the gear box.
Jeremy
battybat
Threads: 29
| posted on April 21st, 2005 at 10:57 AM |
hmmm, don't remeber there being a bar across the top of the gearbox! more research required I think...
Special Air Service
Chief "Gunna"
Threads: 210
| posted on April 21st, 2005 at 12:14 PM |
The bar "across the top of the gearbox" is probasbly still attached to the body.
[size=5] Calling all NSW Mid North Coast Veedubbers
Click Below [/size]
[size=6]Mid North
Coast VW [/size]
ratty 63
A.k.a.: Rossco
Threads: 74
Mood: Just cured my shed envy!
| posted on April 21st, 2005 at 02:15 PM |
posted by Special Air Service
...or has been removed sometime in the past....
R
battybat
Threads: 29
| posted on April 21st, 2005 at 04:11 PM |
seems like there was no bar, another bit to get hold of!
where do these mysterious pieces of metal bolt onto the rear suspension/swing arm set up?
lugnuts
A.k.a.: Mike
Threads: 88
Mood: semi-retiring
| posted on April 21st, 2005 at 04:58 PM |
Dosnt help much but http://www.thesamba.com/vw/forum/album_page.php?pic_id=196933 :duh |
lugnuts
A.k.a.: Mike
Threads: 88
Mood: semi-retiring
| posted on April 21st, 2005 at 05:04 PM |
And http://www.thesamba.com/vw/classifieds/detail.php?id=140735 gettin closer:o |
battybat
Threads: 29
| posted on April 21st, 2005 at 07:52 PM |
cheers guys
reckon I got it worked out - they only seem to fit one way - will post a pic so you can tell me that there is another way...
hopefully it's good and I can get on with the rest of the rebuild
terry
