| [ Total Views: 1284 | Total Replies: 20 | Thread Id: 38272 ] |
seagull
Threads: 752
| posted on April 27th, 2005 at 01:01 AM |
ej22 subaru had a look at one pulled down one done 340000ks !
the machine marks were still in the bore , the only thing I could say was .
carbon in the inlet and on top of pistions and valves
big end had failed due to the above ( may be ) ?
Subaru have a cleaner in a can for the carbon clean .
pete wood
| posted on April 27th, 2005 at 06:50 PM |
What do you mean a cleaner in a can?
barls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
| posted on April 27th, 2005 at 06:52 PM |
intake cleaner/carby cleaner works wonders
Chewy
Threads: 75
Mood: Buggered
| posted on April 27th, 2005 at 06:54 PM |
How did carbon get in the inlet port?
pete wood
| posted on April 27th, 2005 at 08:09 PM |
crankcase breathers into the inlet manifold.
MikeM
Buggy Head
Threads: 71
Mood: :duh
| posted on April 28th, 2005 at 08:58 AM |
posted by seagull
Do you have any more info on this? If I walk into my local Subaru parts outlet what do I ask for?
Maybe we should be putting catchcans on the crankcase breathers. Interesting.
MickH
A.k.a.: Michael Hutchinson
Hairy Gutted Sloth
Threads: 29
| posted on April 28th, 2005 at 10:34 AM |
You ask for mechanic in a can head decarbonizer. They will know what you mean. This stuff works wonders.We did one engine before a tear down and it
looked like new inside on the side that we did and crap on the other side. It is reccomended every 40000km from memory.Have already done the ute. Is
also good in vw engines.:thumb
tssnq.com.au
MikeM
Buggy Head
Threads: 71
Mood: :duh
| posted on April 28th, 2005 at 10:49 AM |
posted by Mick H
So do I get it from Subaru, or do I get it from Supercheap/AutoBahn etc?
56astro
Threads: 74
| posted on April 28th, 2005 at 10:56 AM |
"SuperRoo" made a product that comes in a aerosol can. It is a type of carby or head cleaner that you spray through the throttle body with the
engine running.
Get it from Repco and the like.
35MPG on 101.3kPa
MickH
Hairy Gutted Sloth
Threads: 29
From Subaru.It's a blue aerosol can. Use the genuine Subaru one only available from Subaru dealers.
[Edited on 28/4/2005 by Mick H]
tssnq.com.au
56astro
Threads: 74
| posted on April 28th, 2005 at 11:18 AM |
posted by Mick H
"SuperRoo" is the brand name of a similar product. It has a picture of a cartoon 'roo with tyres as legs, doing a burnout.
35MPG on 101.3kPa
MickH
Hairy Gutted Sloth
Threads: 29
| posted on April 28th, 2005 at 11:34 AM |
posted by 56astro
posted by Mick H
HeHe...toasted roadkill:duh
tssnq.com.au
Brad
Threads: 332
Mood: Manx Buggy Building
| posted on April 29th, 2005 at 10:09 AM |
Maybe we should stop running breathers into ouir manifolds ... sounds like a good idea to me ... I am going to move mine now :>
VWCOOL
Threads: 235
Mood: happy to help
| posted on April 29th, 2005 at 09:28 PM |
posted by Buggy Brad
Non emissions compliance yadda yadda.. Holden does a Cleaner in a Can, too....
Pay your debts, CxxT
seagull
Threads: 752
| posted on May 1st, 2005 at 09:44 PM |
Have a look in the throttel body ( open position ) you can see the black crap that builds up . in there , On to a catch can idea now .
The blue can is from subaru and I found the best
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
| posted on May 1st, 2005 at 10:20 PM |
Sounds like it is a good investment to keeping things nice and clean. It is good when there is a product that is not too expensive in the grand scale
of engines and you only have to use it every 40,000km.
seagull
Threads: 752
| posted on May 1st, 2005 at 10:35 PM |
be sure to check the wires that run to your air flow sensor Hellbus , many subarus that have been crashed have a problem of over fueling the sustem on
start up , I have now seen three putting raw fuel into the sump and washing the pistions ! all due to the air flow maping and blowing shit loads of
black smoke
O any one needs some thined out subaru oil give me a yell !
like 1.5 lts of fuel in the sump
[Edited on 1/5/2005 by seagull]
helbus
A.k.a.: Pete S
Threads: 312
| posted on May 1st, 2005 at 10:40 PM |
I know what you mean. Lucky the motor we have got has not been in a front smash.
The Limo I built had a faulty airflow meter used and the sump got filled with heaps of petrol, so I have seen that effect and it is not good for the
oil.
seagull
Threads: 752
| posted on May 2nd, 2005 at 12:18 AM |
some dont think this can happen ! the last one i see had no cuts to wires , impact in the shelding I was told
hazet
Threads: 19
| posted on May 11th, 2005 at 01:10 AM |
q
it's called :upper cyl cleaner costs around $18,on the can it says to use it every service.
If looked after the ejs will go on for a long long time.
seagull
Threads: 752
| posted on May 11th, 2005 at 01:18 AM |
you still pulling them apart ?
