[ Total Views: 495 | Total Replies: 7 | Thread Id: 38315 ]
Author: Subject: 1200 to 1600,wat do i need?
Memberits63b
A.k.a.: isaac strachan
Threads: 51
Mood: tired
posted on April 27th, 2005 at 09:10 PM
hey i have a 1200cc 6v 63 bug and i am looking at puttin a 1600 in thats 12v,what is required to make a smooth changeover? isaac
Member57kombi
Hannover Elder
Threads: 181
posted on April 27th, 2005 at 10:18 PM
Everthing.
including tinware, exhaust, also a bush for the starter motor hole in the gearbox to convert it to a 12 volt shaft.
You will also need to grind away some of the gearbox so the flywheel will fit(its bigger)
A voltage reducer for the wipers and you will need to replace all the bulbs(globes), dont forget the speedo ones.
Dave
Memberits63b
Threads: 51
Mood: tired
posted on April 27th, 2005 at 10:24 PM
hey i was aware of the electrical side jsut unsure of hte mechanical,where can i pick up a bush from,and how hard is it to grind away the gear box for fit the flywheel?
Member57kombi
Hannover Elder
Threads: 181
posted on April 27th, 2005 at 10:26 PM
Most beetle specialists should be able to get the bush.
And I have heard of people just fitting the gearbox and letting the teeth grind there own way, I wouldnt recommend it but you dont have to grind too much away, just fit it and see where its catching.
The important thing is to use the correct tinware.
Dave
Memberits63b
Threads: 51
Mood: tired
posted on April 27th, 2005 at 10:33 PM
thanks mate i didnt knwo i needed to do that,good to ifnd out tho..cheers.isaac
MemberChewy
Threads: 75
Mood: Buggered
posted on April 27th, 2005 at 10:48 PM
The bellhousing needs to be clearenced at the engine stud/bolt bosses and around the starter motor bush area.
Sometimes material needs to be removed from the entire circumference of the bell housing tho.
MemberChe Castro
ankle straps
Threads: 79
Mood: (( }:-{D]
posted on April 28th, 2005 at 01:21 AM
You will need a later 12v flywheel as well to fit the 12v starter. 12v flywheels only work with 12v starters, 6v flywheels only with 6v starters as they have different teeth.
Make sure you have the clutch correct pressure plate as well, assuming it is the original early style tranny, you use the early Kombi pressure plate which is 200mm (early beetle is 180mm) which has the early style center.
Jon
MemberTnate
A.k.a.: Tom
Threads: 34
posted on April 28th, 2005 at 10:21 AM
When I did my changeover, I used the 6v starter with the 6v flywheel on the 12v engine.
The 6v starter works fine on a 12v system, just dont crank for too long (as in when you are priming the fuel line) as it will overheat.
I have had no problems myself.
Another way (Im just pondering) is using the 1600 engine, with the 6v flywheel/starter and just changing over that generator (but using the 12v fan),coil, sparkplugs and choke. That seems like it should work and sould like a lot less work.
Good luck
Tnate
[ Queries: 40 ] [ PHP: 3.0% - SQL: 97.0% ]
