[ Total Views: 1300 | Total Replies: 11 | Thread Id: 48130 ]
Author: Subject:  rally sprint set up
Memberwombatone
A.k.a.: Michael
Threads: 41
Mood: Ready to race
posted on January 19th, 2006 at 07:34 PM
rally sprint set up
How should I set up a sing axle bug for rally sprints and the like it will run on both dirt and tar? Any help would be appreciated.
Membervwrallycar
A.k.a.: Andrew Rankin
Threads: 83
posted on January 19th, 2006 at 09:04 PM
good question. we used to race a 62 but im pretty sure it was nothing special. will find out some more info for you.
what car are you using and how far are you planning on going with it?
Memberwombatone
A.k.a.: Michael
Threads: 41
Mood: Ready to race
posted on January 20th, 2006 at 09:29 PM
I’m building a car to do the rerun of the 56 Ampol trial. So I’m using a 56 bug with a 1500cc motor, this is to fit into the under 1500 class. Not sure how much power it will put out but it’s a aluminium case with Pobjoy crank, cam and sump, 40 DCN weber, custom ignition, TP heads think 37 and 35 s/s valves and seriously lightened pistons. The motor has more power then my old hotted up 1600 and it revs really well. 1500 gearbox and billet four wheel disc. I will probably end up using a pair of adjustable shocks on the rear but don’t as for the rest still working on it.
Membervwrallycar
Threads: 83
posted on January 30th, 2006 at 04:43 PM
i dont think you will need much more apart from some sump guards that sorta thing. i use konis on my car. its really more of a cruise rather than a race isnt it?
Memberwombatone
A.k.a.: Michael
Threads: 41
Mood: Ready to race
posted on January 31st, 2006 at 05:17 PM
Your right it will have cruise sections in it but it’s not in me to play follow the leader. I am building the car to be used in competition at a club level, eg. Sprints, Hill climbs, Motakhana’s and the like. I’m not building a show car it will be built for action. The sump guard is a good idea jot any pic’s of one? What konis do you run? I’ve grabbed a set of adjustable off one of the FV we have but don’t really want to use them in case I damage them. Any Idea’s on sway bars or camber comps? What size tyre do you run and what make?
Membervwrallycar
Threads: 83
posted on January 31st, 2006 at 08:56 PM
im not running a sump guard even though i should b.
konis i use are just the red ones, aparantly yellow are not made for my 1500????
i run a 16 or 17mm swaybar up front, none on the rear but mine is IRS.
tyres are proper rally tyres 195/65/15
Memberwombatone
A.k.a.: Michael
Threads: 41
Mood: Ready to race
posted on January 31st, 2006 at 10:12 PM
About tyres I’m not permitted to run rally tyres (mores the pity) Am looking at Pirelli Dragons in 195/65/R15 front and rear. My question is are these two big for the front of my car? Just afraid they will not bite in on grass or dirt. Also how hard or soft do you run your suspension, any idea on what your corner weight might be?
MemberBiX
Threads: 154
posted on February 1st, 2006 at 08:46 AM
I am more into autocross and khana cross, but also dabble in hillcimbs, sprints etc. Though i do run a super, so not much teh same. I found i needed slightly wider rear tires 205, as used the wider rears to help stop oversteer at speed, and then suspension setup to stop understeer at low speed. I run koni sports, and fidn they are pretty good, with stiffer front springs ok for smooth stuff, but on a proper rally sprint/rally ti would be to stiff. I know if a rally beetle being built for qrc (well is log booked already) i will go and check it out and see if i can get some ideas. unless he sees this thread.....
Go hard or go home!!!!
Membervwrallycar
Threads: 83
posted on February 1st, 2006 at 04:43 PM
hey Bix can you get me some pics of it?
Memberrallydave
Threads: 0
Mood: busy!!!
posted on February 4th, 2006 at 07:06 AM
Hi blokes, i've just built and logbooked a 70 swingaxle rallycar in brisbane. To answer your question,not a lot!!!!YES BIX i saw the thread......your round oz event will be harder than u think! concentrate on COLD oil,removing lots of exhaust,and the one everyone forgets,supply LOTS of COLD fuel.engine specification will ultimatley be determined by the supplementy regs for the event and which classes u can run under,PRC HISTORIC,CLASSIC etc.running other events after may only require minor mods to build a JET!! i'm runnig kybs at the front, modified hyundai terracan fronts at the rear,1600 std barrels,std rods, 69 crank,39/35 valves on heavily ported heads,twin 44s,engle 120,light flywheel. std ratios with home made phantom grip lsd,(WORKS GREAT!!!)oil cooler over gearbox with thermo fan,std brakes(well u want to go fast don't u!)i does 100mph indicated with 14in delta mags and revs to 5800 before valve bounce on std valve springs pulling hard all the way. posting pics here is a pain contact me on david.scharf@bigpond.com.au for some pics ,i'll email. running kcf short course rally end of feburary at jimna in brisbane. i'll help anyone interested in running more beetles in ralllies.
Memberwombatone
A.k.a.: Michael
Threads: 41
Mood: Ready to race
rsvdclap.gif posted on February 4th, 2006 at 03:41 PM
Dave will send you and email, would love to see some pics.
MemberBiX
Threads: 154
posted on February 6th, 2006 at 09:03 AM
You beat me to it dave, if you want service crew for kcf/qrc let me know. I will give you call soon and pop up and see the car, been very busy with work :(
[ Queries: 40 ] [ PHP: 13.2% - SQL: 86.8% ]
