[ Total Views: 993 | Total Replies: 7 | Thread Id: 49167 ]
Author: Subject:  painting of my beetle
Memberchinesefishysauce
A.k.a.: VIN Seng
Threads: 14
Mood: lost at the moment
posted on February 21st, 2006 at 09:56 PM
anyone just wonder if it cheaper to sand my beetle down to bare metal and send it to a paint shop.pls advise.thanks
Fish
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on February 22nd, 2006 at 07:11 AM
Any preparation work undertaken by yourself will save money. Something like stripping shouldn't be a big problem, however sometimes panel beaters/spray painters will be reluctant to finish the body work that someone has started as there may be more work to correct mistakes. However if it was just stripped this problem wouldn't exist.
A.k.a.: VIN Seng
Threads: 14
posted on February 22nd, 2006 at 09:01 AM
Hi Allan
where would you recommend for the spraying job in gold coast? do you know roughly how much will it cost ?
and also if i would to hire my own air compressor to spray myself, would you advise ...thanks
Fish
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on February 22nd, 2006 at 11:21 AM
Unfortunately I haven't had any experience with any paint/panel shops on the gold coast so can't provide a recommendation. If you decide to do it yourself I am happy to give you any advice/feedback/recommendations - it will be cheaper but depends ultimately on what sort of result you are hoping to achieve (and how much patience and time you have). I did all of my rust repair, panel work and paint in my garage but it took around 8 months! (after work, weekends etc).
If you have no gear that can be expensive to set up as well. You could drive around to a few paint shops and ask them if they were willing to spray the final coat if you did all the prep work, and maybe try to get an idea of cost - if you want them to do it from bare metal be prepared for quite a hefty price tag. Perhaps Helbus could give you an idea as he is in the trade. Simple things like removing all trim, windows, interior etc etc will save you a lot of cash. Just remember you will pay someone by the hour, so for every hour of work you can't do yourself you'll have to pay anywhere between $40-80/hr for them to do.
There is a lot of time involved to do a good job, hence why it won't be cheap ($5-8K at a very rough guess, but a lot less if they were just to shoot the topcoat over your prep - if you go this way you need to ensure you use primer/sealer etc that is compatible with the paint they use).
A.k.a.: VIN Seng
Threads: 14
posted on February 22nd, 2006 at 11:04 PM
thanks again
i just brought the sander with 800grit and start to sand the bug right now with my hand .but i have a problem, where can i get a 50L air compressor with maybe 2.5 hp...and also after sanding what should i do next ..cause i was told to use etch primer...it is right ...please advise
Fish
Memberbugeyedbabe
Threads: 64
Mood: In love with a SMURF
posted on February 22nd, 2006 at 11:32 PM
fish,
here is a link that may help.
http://forums.aussieveedubbers.com/viewtopic.php?tid=35465&page=1#pid320366
I was asking the same stuff...ie how to do it if i do it myself, and i ended up readng heaps, the summarising it down to dot points.
it has llink in that same thread, and as u guessed dasduber(alan), dubcrazy(steff) and helbus(pete) are great for asking adive of...pete and steff work in the industry, and alan did it all himself (he is a well known legend to avd members)
hopefuly reading the other link, and its dot point summary will help.
It basically si alot of hard work, and alot of patience
good luck with ur resto...
beb
[ Edited on 22-2-2006 by bugeyedbabe ]
dubless. :fakesniff:
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on February 23rd, 2006 at 12:00 AM
Fish, definitley be prepared to give it a go. However you must not believe for a moment it will not be hard work. It will be dirty, frustrating and also rewarding.
There are quite a number of sticky threads at the top of the Paint & Body section made sticky so people like yourself can spend a fair time reading. It is not just what has been written in those sticky threads, but the questions asked by other members may very well be exactly what you are thinking of asking.
The other thing to remember too is that a lot of experienced guys dont have set rules or answers to some questions. It becomes experience, gut feeling and 'just because' Some guys can get the same result with three different types of sandpaper, because they have the experience to alter their work pattern as required. This is often made necessary due to running out of certain materials, or just plain laziness :)
If you are going to strip to bare metal I suggest a fibre backed clean 'n' strip disc. Will go straight on you angle grinder instead of a grinding wheel and about 4 discs would do the whole car. $16-$20 each depending on grinder size. I wouldn't guarantee Bunnings or Supercheap would have them or have even heard of them. You need an abrasive specialist (Yellow Pages under Metal Polishers supplies maybe)
SIA strip discs
http://www.sia-abrasives.com/fibral/en/89E7CE71A9394D11840AD80ABC2B17FD.html
Membervolks67
A.k.a.: Bob Priestley
Threads: 20
Mood: happy
posted on March 6th, 2006 at 09:41 AM
firstly, if it is like all veedubbs probably had two or three resprays, if your paint thickness goes over 300 microns you will paint cracking and crows foot on the panels.
I would personally take the panels back to bare metal, then etch prime and then hiigh fill, then colour coat.
VERY IMPORTANT use only quality paint brands like Spartan or Dulux do not get sucken into brands like concept paints or grebber the paint to use is the one used by the car manufactures. and use aaa premium general purpose thinners and gunwash to keep the spraying gun clean .
I dont know much about the coast but i would go to a good panel shop on the coast eg like the bmw dealers at soputhport and see where they get their paint supplies from.
Presitige Paint and Panel Equipment supplies in Brisbane is a good one and Spartan paints at archfield.
If you are doing the whole car you will probably get trade much cheaper than buying secondrate products from the like bunnings and super cheap stay away from those bandits.
catch you soon,
bob
[ Queries: 40 ] [ PHP: 6.7% - SQL: 93.3% ]
