[ Total Views: 913 | Total Replies: 1 | Thread Id: 49596 ]
Author: Subject:  Fuel tank.
Memberfirefly
Threads: 9
Mood: Enlightened
posted on March 7th, 2006 at 11:00 PM
Fuel tank.
Ok the fuel tank in the beetle has what looks like a overflow/breater line on the filler neck (1960 model) This is missing a (I assume rubber) hose and thus a replace is needed to be sort. What do I replace it with (assume normal fuel line) and where is it to be run too...?
T
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on March 8th, 2006 at 07:12 AM
As it is just a breather line, any small diameter rubber hose will suffice - just make sure it is a tight fit onto the breather pipe on the filler neck. Just in front of the corner of the tank, there should be a hole in the body which this tube normall passes through to vent out under the car.
[ Queries: 40 ] [ PHP: 10.2% - SQL: 89.8% ]
