[ Total Views: 884 | Total Replies: 5 | Thread Id: 51991 ]
Author: Subject:  Primer/Surfacer/Putty gun tips.....
Memberctefeh
Threads: 30
Mood: grimly determined
posted on May 10th, 2006 at 01:22 PM
All,
Just wondering if there is a rule of thumb of sorts for tip sizes for the products? I have a "finishing" gun (can't remember the tip size but it does a great job) and was wondering whether I should pick up a second gun for spraying primer/surfacer. And is a putty gun different again?
The plan is to practice, practice, practice on spare panels I have so I'll be stripping and re-coating a few times trying out about 3 different colours of base/clear topcoats.
TIA
Ctefeh
Memberkillakornkobb
A.k.a.: Damien
where's that clutch?
Threads: 149
Mood: Pierced
posted on May 24th, 2006 at 05:13 PM
primer being a higher build product requires a larger fluid tip size, normally 1.8mm, where as a top coat gun would be 1.5.
i have a devilbiss GTi topcoat gun, and use an old SATAjet as a primer gun, i would NEVER put primer in my topcoat gun.
Tagedeezee Heezy
Memberctefeh
Threads: 30
posted on May 27th, 2006 at 06:53 PM
Thanks...
Damien,
Thanks for that, I'll hunt around for a larger tip second gun.
Regards
Sean
Membert2
stop taking life so serious
Threads: 206
Mood: tired
posted on May 28th, 2006 at 08:45 AM
polyester /putty gun requires a 2.5 mm gravity feed gun, well thats what i used
gravity wont get you high
Memberkillakornkobb
A.k.a.: Damien
Threads: 149
Mood: Pierced
posted on May 28th, 2006 at 12:29 PM
yeah polyester guns tips are huge, cos the shit is SOOOOO thick:) and smells awesome.. but dont tell workcover i know that :D
Tagedeezee Heezy
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on May 28th, 2006 at 05:55 PM
Personally I have never used and never finish my panel work to require to use polyester filler. I belive if there is nothing to shrink back, it cant shrink back. Try to finish to at least 180 grit paper with your filler and you will have a great finish that will last a long time.
Regular primer filler on a 180 grit finish will work quite well through a 2.0 tip gun.
[ Queries: 40 ] [ PHP: 11.6% - SQL: 88.4% ]
