| [ Total Views: 620 | Total Replies: 4 | Thread Id: 5263 ] |
david
Threads: 157
Mood: amicable
| posted on April 13th, 2003 at 05:16 PM |
66 bug rear suspension question
i have pulled the rear spring plates off and moved them up two notches to lower my bug ,i did all the right things like marked everything etc should
there be much slack play in the arms now and also one seems to be sitting a little different to the other, i have read one end of the torion bar has
40 teeth and the other 44 ,how would i start resetting the bars from scratch ,does anyone know of any tech article,s i could check out and do i need
to get shorter shock absorbers
dave:o:o
p.s. i tried wes's thread but the file would not open
[Edited on 13-4-2003 by david]
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on April 13th, 2003 at 05:37 PM |
The kombi workshop manual specifies the angle that the torsion bars should hang at when the car is off it's wheels, and I expect the Beetle
manual would do the same. You don't need to know the stock setting though.....
The kombi manual also illustrates how to measure that angle, as well as listing the procedure to adjust it, using an spirit level designed to measure
the angle from horizontal. I bought a cheap one of these for $9, but a better quality one was available for $44. I'm happy with the $9, it does
the same job. I would buy one if I were you.
Basically you can pick which side sits at the best height for your personal preference, and then adjust the other to match.
To open Wes's file, download the .exe file and save it to your desktop, then rename the file so that it actually ends with .exe
Then download the .dll file and save it to your C:\WINDOWS\system folder. You should then be able to run the program by double clicking it on the
desktop.
Kruizin Kol
blownKombi
Threads: 4
Mood: lazy
digital level works for me
if you can get your hands on a digital level go for it. My dad is an engineer and when we reset my last kombi he couldn't belive how much easier
it made it.
kombi_kid
Good Kid too many projects
Threads: 341
| posted on April 13th, 2003 at 10:37 PM |
inner splines are used for more specific adjustments hence the more teeth on the inner end. trying jumpin up and down in the car maybe they just need
to be settled down!!!
rhys
555bug
WRX Bug Boy
Threads: 79
Theme: UltimaBB Vintage
Mood: turbo charged
| posted on April 14th, 2003 at 10:43 AM |
you may already have this but it's handy for those that don't. |
56astro
Threads: 74
| posted on April 14th, 2003 at 01:29 PM |
Try these sites
http://www.geocities.com/aussiebug1970/rearaxle.html
http://oldeskool.org/tech/tech.html#rear
When I did mine the first time I was extremely cautious to keep a track of where the original position was.
I realised that wasn't necessary, all you need to do is make sure that they both end up at the same angle. Make sure you measure the angle with
the weight of the spring plate supported (not hanging unsupported).
35MPG on 101.3kPa
david
Threads: 157
Mood: amicable
| posted on April 14th, 2003 at 07:29 PM |
hey thanks guys
it is rather daunting when you first pop the arm of and it scares the shit out of you but after looking and checking a heap of times i think it is
alright ,if i am lowering it two notches is it right that it does not have any preload on it when i put it back on, i have not bolted it all back
together yet but i hope i am doing it the right way
dave the apprentice :o:o
[Edited on 14-4-2003 by david]
david
Threads: 157
Mood: amicable
| posted on April 16th, 2003 at 07:42 PM |
uneven
have put it all together and jumped up and down but still uneven ,bugger ,so back to the drawing board turns out it would be a bit low any way, have
to do a bit of fine spline adjusting hope to get it right to drive to sydney on friday
david:o:o
56astro
Threads: 74
| posted on April 16th, 2003 at 08:50 PM |
Make sure when you put it all back together to check the height that you haven't got the shock absorbers connected. When I did mine last time
(with the body off) the shockies contributed to a false "reading".
A good spot to measure from is the lip that stops the spring plate from dropping too far. Use that lip as the reference point on both sides.
35MPG on 101.3kPa
