| [ Total Views: 1225 | Total Replies: 7 | Thread Id: 58281 ] |
mattie182
Threads: 108
Mood: Buggy On
| posted on November 7th, 2006 at 07:25 AM |
Fuel lines
How do I tell which fuel line is the inlet and which is the outlet, on the EJ22????:o
Once you go flat, you never go back!!!!!!
ElusiveStranger
Threads: 30
| posted on November 7th, 2006 at 08:42 AM |
If it's like an EJ20 the IN line runs to the right hand side of the block when viewed from the pulley end. It then goes to the left of the block and
the pressure regulator is on the outlet pipe, just past what would be No 3 on a Volksie lump.
HTH
mattie182
Threads: 108
Mood: Buggy On
| posted on November 7th, 2006 at 09:05 AM |
It has three lines all on the same side, (the right hand side)
One is 'breather' which runs through a canister, just not sure which one is which for the other two
mat
ElusiveStranger
Threads: 30
| posted on November 7th, 2006 at 09:39 AM |
Re-read what I typed
The IN line first supplies the RHS of the block when viewed from the pulley end. Trace the RHS rail back to the 3 pipes, that's the inlet (pops
outside in the cold, dark & rain) Inlet on mine is the uppermost of the 8mm pipes
[ Edited on 6-11-2006 by ElusiveStranger ]
mattie182
Threads: 108
Mood: Buggy On
| posted on November 7th, 2006 at 11:44 AM |
ahhhhh Thanks
ElusiveStranger
Threads: 30
| posted on November 9th, 2006 at 07:53 AM |
Did you sort it & is it running yet?
mattie182
Threads: 108
Mood: Buggy On
| posted on November 9th, 2006 at 08:10 AM |
sorted, not running..
Still got the wiring and the exhaust
ElusiveStranger
Threads: 30
| posted on November 9th, 2006 at 09:05 AM |
posted by mattie182
Ahhh, the easy bits
