[ Total Views: 1308 | Total Replies: 2 | Thread Id: 58381 ]
Author: Subject:  what is the best way to bring it to bare metal?
MemberLearner
A.k.a.: Lionel Luu
Threads: 55
posted on November 9th, 2006 at 07:38 PM
hello all i got a beetle 4 months ago as a project baja. however i'm using it as a family car for now until i ofund something else. just yesterday i decided to lift the carpet and found some surface rust what should i do to prevent it to go any further until i redo the whole thing (probably a year) same for a few spots around the car. should i just sand back to bare metal and then what?
thanks ppl (i've never worked on a car before so please don't be afraid to tell me the most basic (that's probably what i need)
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on November 9th, 2006 at 10:31 PM
If you are going to fully restore it in a year and pull the whole body apart, then just a quick coat of rust converter will hold it off temporarily.
If you are restoring it, then remove the surface rust all off using mechanical means. An angle grinder with a twist knot cup wire wheel will do good, and then a coat of rust converter and let it dry for a few days until the metal turns bluey black.
The ultimate is to sand blast the pan and then POR15 or Rustbullet coat it.
MemberRENNWAGEN
A.k.a.: shane
Threads: 43
posted on November 10th, 2006 at 06:06 PM
Speaking of rustbullet, apparently Volksfolks is not distributing it anymore does anyone know who is?
[ Queries: 40 ] [ PHP: 8.6% - SQL: 91.4% ]
