| [ Total Views: 1452 | Total Replies: 12 | Thread Id: 59383 ] |
micah
Mood: happy
| posted on January 7th, 2007 at 04:14 PM |
where can i get ej20tt parts
hey i am putting a subaru ej20tt in my 72 super and i wanted to know if anyone knew where i could get parts for that motor i am looking for a fuel
pump and a fuel pump control module any help would be great
thanks a bunch
seagull
Threads: 752
| posted on January 7th, 2007 at 05:20 PM |
is it a GTB or TT legacy
what do the injectors look like , are they yellow tops ?
micah
Mood: happy
| posted on January 8th, 2007 at 08:53 AM |
ej20tt
so this is what this what the receipt says JDM Subaru legacy BG5 A/T Twin Turbo engine set so i guess that means its a legacy tt
the injectors are gray
if you need any more info just ask
thanks a lot
micah sauter
gull
Threads: 34
| posted on January 8th, 2007 at 03:51 PM |
yellow top injectors would make it a GTB ( STI ) in my book .
Are you using the stock ecu ( full harness ) ??
micah
Mood: happy
| posted on January 9th, 2007 at 01:41 PM |
yep i am using the stock ecu (full harness )
mo 1303
Threads: 6
| posted on January 9th, 2007 at 05:31 PM |
I have a fuel-pump from a ej20tt . The same engine as yours . And also a Impreza STI pump . I´ve send you a "U2U" !
seagull
Threads: 752
| posted on January 10th, 2007 at 12:53 AM |
There is a few things you need to keep in mind as you just have the loom & not the whole front cut to work with .
1) the subaru * auto * has a inter lock with the foot brake & the key ( auto needs to be in park in the subaru before the key is able to be removed
.Power is set to the ecu for 3 seconds via the auto .You need to look at the wiring diagram as to get this right .
2) you would be able to get a stand alone fuel pump over there , easyer than mounting the oem unit in a tank .
can you get the numbers off the ecu ? & post them up here .all going well I may have a diagram
The motor you have would be a closed deck 200kw unit
welcome to the dark side
:vader
seagull
micah
Mood: happy
| posted on January 10th, 2007 at 11:59 AM |
http://au.geocities.com/twinturbosubaru/
this is the wiaring diagram
where can i get a fuel pump and control module do i have to go to japan for that or does anyone in the us have something like that
gull
Threads: 34
| posted on January 10th, 2007 at 01:05 PM |
what are you calling a control module ?
purchase a fuel pump that is a stand alone ( not in the fuel tank ) bosch 044
the other site is http://www.rslibertyclub.org heaps of info on there
boof2332
Threads: 120
Mood: Sympathetic
| posted on January 12th, 2007 at 05:08 PM |
you would think that the control module, whatever it is, would be the same on sti's if the pump is the same, or on the twin turbo motors that came
out here or in the U.S. That said, subaru should sell them in any country that sti's or twin turbo liberty's were sold.
Matt
mo 1303
Threads: 6
| posted on January 12th, 2007 at 05:39 PM |
i have a tt pump . i will have a look for the control modul .
will back in few hours .
mo 1303
Threads: 6
| posted on January 12th, 2007 at 08:14 PM |
no control module
micah
Mood: happy
| posted on January 27th, 2007 at 07:04 AM |
tt pump
how much do you want for that tt pump
