[ Total Views: 1217 | Total Replies: 7 | Thread Id: 60322 ]
Author: Subject:  Anyone using the GT40T transformer type coil?
MemberStanley
Threads: 270
posted on February 9th, 2007 at 07:53 PM
Is anyone using the GT40T transformer type coil? If so are they worth the extra $.
Oops....wrong forum...sorry
[ Edited on 9-2-2007 by Stanley ]
Memberdangerous
Mood: 591
posted on February 10th, 2007 at 06:21 AM
This type Andrew?
Mine has served me very well over the years,
but I heard a standard OIL FILLED coil is a better deal.
http://i113.photobucket.com/albums/n216/dangerous_05/MSDCoilConnections.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/MSDCoilConnections2.jpg
Originally posted by westi
That's mad Alan.
MemberStanley
Threads: 270
posted on February 10th, 2007 at 07:13 AM
Thats the one. They say they have many advantages over the oil filled one. stronger spark better heat dissipation etc. and the're more compact.
posted on February 10th, 2007 at 08:40 AM
One of the locals here has used them on beetles, but I have always used the oil filled coils...
I don't think there are any real advantages..
the red GT40 coils also put out a higher voltage spark...
MemberTazz
A.k.a.: Tazz Devil
Old Skool
Mood: facisious
posted on February 10th, 2007 at 09:02 AM
Andrew.... the "T" coil has good spark but are known for overheating and shorting out. Long trips and engine heat will shorten the life. I have fitted these to all sorts of cars over time and most have failed because of the lack of heat dispersion.
If your looking for more spark look at maybe msd or accel.
The MSD has heatsink built-in and works great at dispersing the heat fast.
The compact design is great for fitting into limited space
http://www.bavariant.com/blog/uploads/msd_8207.jpg
Accel is still oil filled but is still one of the best Hi-Po coils around..
But.. is Huge and you might not have the room.
http://www.car-stuff.com/images/part_image/accelcoil.jpg
Tazz
1962 Type3 Squareback
1967 Type3 Fastback "Kermit"
MemberStanley
Threads: 270
posted on February 10th, 2007 at 09:23 AM
thanks all...oil filled GT40 it is then.
Membersilver
Dangerous when poked
Threads: 162
Mood: In 2 Minds
posted on February 10th, 2007 at 10:18 AM
What about GT40R
Keeping it real !
MemberTazz
A.k.a.: Tazz Devil
Old Skool
Mood: facisious
posted on February 10th, 2007 at 01:19 PM
The only difference between the 40 and 40R is the the 40R uses a resister.
The 40R is great for use in 6v motor's as it doesn't need the high voltage and the standard 40.
Tazz
[ Queries: 40 ] [ PHP: 14.5% - SQL: 85.5% ]
