[ Total Views: 993 | Total Replies: 3 | Thread Id: 6201 ]
Author: Subject: my ride
Memberbus914
Threads: 233
Mood: Could be worse
posted on May 9th, 2003 at 11:00 PM
my ride
One owner till 2000, service record shows total of all 83000 miles.
Speedwell BRMs by gimp, researching this combination...
CB 1955 D.I.ENG KIT 76X90.5, 5.400" SUPER RACE RODS, stroker "B" pistons
CB 044 SPECIAL with 40 x 35.5mm S/S valves, Single Hi-Rev Springs
CB Dual 44 IDF Kit, T-3 Dual Port
CB 90.5 TOTAL SEAL PRO SET
Webcam Billet Lifters
Webcam #163 grind, 0.422" lift, 284 deg duration, 249 @.050
bugpack MINI SUMP KIT
full flow filter kit with plugged 26mm pump
GENUINE 911 ADJUSTERS
(Aircooled.Net) SUPER-HD Aluminum Pushrods
CB HIGH PERF. ROCKER SHAFTS
S&S tuned length 1-1/2" ceramic coated merged Type 3 header
Kennedy Stage 1 1700lbs 200mm Clutch pressure plate
CB Lightweight Forged Chromoly Flywheel
(Aircooled.Net) Bosch SVDA (SDDA) Distributor, with vacuum advance
COMPUFIRE electronic ignition module
MemberOvalGlen
Threads: 46
Mood: Change
posted on May 10th, 2003 at 01:25 AM
Very nice specs, certainly something to rave about.
Bet it has good Torque.!
Good Car, did you put it all together.?
Regards,Glenn>
Memberfish
Threads: 32
Mood: just cruisin
biggrin.gif posted on May 10th, 2003 at 05:10 AM
hey thats one nice lookin bug!!!
Drink and drive your a bloody idiot!!! make it home you'r a legend !!!!
Memberbus914
Threads: 233
posted on May 12th, 2003 at 07:45 AM
i pulled it apart shortly after that pic was taken to paint the floorpan, and its been in pieces since. can't say how it goes, it hasn't been built yet. expecting longevity, responsiveness, and good torque.
MemberKruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
posted on May 12th, 2003 at 03:17 PM
Lookin forward to seeing the finished pics. :thumb
Kruizin Kol
MemberUnity-28
TOO LOW? NEVER
Threads: 146
Mood: Tucked In nicely!
posted on May 12th, 2003 at 03:56 PM
NIce lookin BUG????? Its a fasty!
But it is nice!
N!
Memberkustomkool
A.k.a.: Damian Von
BEING KOOL AINT CHEAP
Mood: farked up...
posted on May 13th, 2003 at 11:43 AM
Dont be so cruel to it when you put it back together how would you like walking around on youre tippy toes..SLAM THAT FASTY>
[ Queries: 40 ] [ PHP: 6.1% - SQL: 93.9% ]
