[ Total Views: 1161 | Total Replies: -1 | Thread Id: 644 ]
Author: Subject: Keyed or Splined shafts?
Member56astro
Threads: 74
posted on September 16th, 2002 at 08:29 PM
I have an L Bug (single side plate) tranny and need to know if it has a splined or keyed main shaft and pinion shaft.
The reason I hear you ask? I'm about to order a set of gears off Albins and they need to know. (I hope they're keyed 'cause the gears are cheaper!)
35MPG on 101.3kPa
Member56astro
Threads: 74
posted on September 18th, 2002 at 07:57 PM
Anyone .....
anyone .... ??
35MPG on 101.3kPa
Membersplitbusaustralia
Threads: 65
posted on September 19th, 2002 at 11:38 AM
I'm 99.999% sure it would be splined. But I've never pulled one down and don't have the manual to check.
MemberBuggy Boyz
Threads:
posted on September 19th, 2002 at 12:07 PM
Pull it apart
Shouldn't you pull it apart before you order them ?
If you give German Autos a call on 07 3865 5457 Lawrence should be able to tell you off the top of his head for sure.
