| [ Total Views: 3763 | Total Replies: 19 | Thread Id: 65933 ] |
Pault
Threads: 19
| posted on November 4th, 2007 at 09:54 PM |
Jack for Country Buggy
Hey can someone tell me did the country buggy's have a special kind of wheel jack, or is it the same kind used for a beetle or kombi.
I need one for my car.
Regards
Paul
58camper
A.k.a.: Bill Moore
Threads: 110
Mood: Curt but friendly
| posted on November 6th, 2007 at 07:13 PM |
Paul,
The CB jack is the same as the Beetle jack except for one thing- it is about 4 inches longer in the reach to allow for the greater ground clearance of
the vehicle. In the short term use a standard Beetle jack with a brick or block of wood under it so you can get the car far enough off the ground.
Regards,
Countrybuggybill
Pault
Threads: 19
| posted on November 6th, 2007 at 09:41 PM |
Hi Bill,
Thankyou once again for your assistance. You've answered many of my questions and it is very much appreciated.
Regards
Paul
nbturbo
Threads: 89
Theme: UltimaBB Powder
| posted on November 13th, 2007 at 01:00 PM |
Get yourself a steering shaft from a 6 volt Beetle-cut it to whatever length you need-get somebody to machine the circlip grooves each end and you
will have a suitable CB jack.The shaft is the same 22mm OD and 3mm wall thickness as a Beetle jack shaft.
bevoracing
A.k.a.: Tony Beven
Threads: 36
Theme: UltimaBB Vintage
Mood: Leaning against the shed wall !.
| posted on November 2nd, 2009 at 01:31 PM |
I recently came into possession of what I think is a genuine CB jack. While overhauling it I measured the shaft. It’s exactly 550mm long which, if
it is real, may be of interest to someone modifying one. The 2 pins were worn out and the roller was worn through. Other than that it’s in perfect
condition and will be an easy rebuild.
Does that sound like a genuine one to you blokes? I don’t have a beetle or kombi one to compare it with.
Tony
| Error |
58camper
A.k.a.: Bill Moore
Threads: 110
| posted on November 2nd, 2009 at 07:51 PM |
Tony,
Your post made me go measure my CB jack and you are spot on with the 550mm long.
Sounds,looks and even smells like the duck's guts.
The length of the shaft is the only difference at I know about.
countrybuggybill
68AutoBug
posted on November 2nd, 2009 at 08:23 PM |
Jacks and CB Lamps...
there are probably vw owners out there with a CB jack and wouldn't know it??
although a jack 4 inches longer wouldn't fit under My bonnet
in the jack clamps on the RHS next to the spare wheel...
a CB jack would need the handle with a bend in it???
from memory early jacks could go straight down in one go???
where as the later jack [bilstein with a pressed metal base]
had the two separate sockets to place the handle in..
and they go down a bit at a time...
am I correct???
PS: the front blinkers on country buggies...
they are still available new ?? I saw some in a local shop..
fairly expensive for something that used to cost a few dollars.
not sure about the tail lamps?? they were just generic Hella lamps too weren't they??
68AutoBug
| posted on November 2nd, 2009 at 08:24 PM |
posted by nbturbo
How in the world did you come to measure those???
58camper
A.k.a.: Bill Moore
Threads: 110
| posted on November 2nd, 2009 at 08:28 PM |
Lee- you are right about the CB jacks not fitting in a Beetle.
The Hella front and rear lense units are still available although the rears are now plastic chrome and 12V. The rears sell for about $50 and the front
Hella lenses are about $35.
Navra make the same items as the Hella units but I dont see them that much cheaper at $39 for rears and $25 for the fronts.
countrybuggybill
68AutoBug
| posted on November 2nd, 2009 at 08:37 PM |
Hi Bill,
Narva used to be located in the DDR or German Democratik Republik [eastern germany]
and their driving lamps and switches etc...
used to be much cheaper than Hella...
then they pulled the Berlin Wall down and it became a German Company... and its products have improved.. along with its price
I bought a pair of rectangular driving lamps off ebay a few years ago.. they were Holden official accessories.. lol
and made by NARVA.. with DDR on the lens... lol
they were still sealed in their boxes...
I think I have a new front blinker lamp somewhere too...
I know I have a clear one i never used... lol
the retail price of Hella & Narva lamps are rediculously expensive these days...
bevoracing
A.k.a.: Tony Beven
Threads: 36
| posted on November 3rd, 2009 at 07:57 PM |
Well, here it is, all 550mm of it. 2 new pins and a roller (all hard) and a bit of a clean up and it’s like brand new.
You have to appreciate the simplistic design, excellent functionality and quality of a thing like this. Reminds you why you like these VW based
things.
Tony
| Error |
| Error |
68AutoBug
| posted on November 3rd, 2009 at 08:18 PM |
I found in the US and the US & Canada...
no one uses the VW jack...
I've been using one since 1962... [My Fathers]
I've never known one to come down...
even when greased or oiled.... ????
Excellent designs... both of them...
there was a third design in real late beetles but I've never seen one.. maybe the uSA only ???
68AutoBug
| posted on November 3rd, 2009 at 08:19 PM |
posted by bevoracing
things.
Tony
You could have put 13 inch wheels on the buggy and You could have used a beetle jack.... lol
or lowered the jacking points... lol
ztnoo
Threads: 120
Mood: Dazed & Confused
| posted on January 21st, 2010 at 07:51 AM |
CB jack on right, Beetle jack on left.
Fine tuning the proper daily ratio of Maxwell House to Bacardi 151.........
* Don't worry about the world coming to an end today. It's already tomorrow in Australia !
CBKO294
Threads: 12
| posted on January 8th, 2015 at 01:58 PM |
Hey Beven, your jack looks really nice. What did you use to clean it up? It has that nice old firearm look to it. Where did you get your pins and
roller?
bevoracing
A.k.a.: Tony Beven
Threads: 36
| posted on February 2nd, 2015 at 08:50 AM |
Yes it came up great, I was quite pleased.
No tricks to the finish. It came from a big sheep station (ranch) in a very dry area of Australia. It was obviously well used, and then dumped on
the sand the open for 35 years. The surface was lightly rusted. All I did was brush it with various wire wheels and hand brushes, not too heavily,
and then oiled it. I guess a wax or a varnish of some sort would do the same job. Perhaps one of those products that they preserve “patina”
with?
As for the pins and roller, I just knocked it apart, measured it up and made those bits myself, in the lathe.
It’s now sealed in a plastic bag waiting for the rest CB to be completed.
Tony Beven
nbturbo
Threads: 89
| posted on February 2nd, 2015 at 10:00 AM |
Tony , I have just restored another one as well. It's the one I use for lifting the spring plates back up to get the rubber bush cap bolts back in.I
have turned the workings around to get it to work in reverse. Works a treat.
bevoracing
A.k.a.: Tony Beven
Threads: 36
| posted on February 3rd, 2015 at 09:32 AM |
Hi Gary
Yes, I’ve heard of people using them for that. Their compact size and positive action makes them great for the job. Only possible draw back is the
“down” mechanism. You sort of have to commit to the release, all or nothing. They certainly get your attention that first time you let a car
down with one. All part of the fun I guess.
Did you get those CB rear axles done?
Tony
nbturbo
Threads: 89
| posted on February 3rd, 2015 at 08:27 PM |
With some careful manipulation,they can be eased down.I had the reduction box axle tubes blasted and painted,but I have a dual sideplate IRS box at
Volkscare being converted to swingaxle and having the crown wheel swapped sides.I will rebuild the reduction boxes and fit it all to that trans when
he is finished.Should be a good cruiser with a 1600 TP mated to it.
nbturbo
Threads: 89
| posted on February 4th, 2015 at 12:24 PM |
Been thinking about the CB jacks- seeing all the running gear is Kombi based and split Kombis have the same type of jacking points- then one would
assume the jack was from a Kombi ???
