| [ Total Views: 1488 | Total Replies: 7 | Thread Id: 68620 ] |
bigdave
Threads: 98
| posted on April 19th, 2008 at 08:42 AM |
Lowering front end? Big job/small job?
How difficult a job is it to lower the front end on a 73 Fastback? The rear end seems to have lowered itself over the years, so I was thinking of
lowering the front to suit. Is there any detailed instructions around? I did a search on here with no luck.
Dave
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on April 19th, 2008 at 08:55 AM |
easy, don't have to cut and weld or anything, dissasemble,just drop some splines re assemble and alignment.
i have'nt done it in a while tho, so someone will pop up and explain the details no doubt
bigdave
Threads: 98
| posted on April 20th, 2008 at 06:50 PM |
How low before ther are issues with steering/tyres? Only want to drop maybe 1'1/4 or 1'1/2. How many splines would this be?
Dave
Volkswagenboy
A.k.a.: Brenton Barry
Staggers Automotive.
Threads: 92
Mood: Indifferent
| posted on April 20th, 2008 at 11:18 PM |
One spline should be ok, I've gone two splines and it scrubs on the guard just a little on full lock.
Here's a link to my Type 3 thread:
http://forums.aussieveedubbers.com/viewtopic.php?tid=68235
-Staggers.
GTMac
A.k.a.: Andrew
Threads: 246
Mood: Always asleep
| posted on April 21st, 2008 at 11:47 PM |
Yes would agree 1 spline is about right before steering/clearance issues arise and is what I did on mine. Top of tyre sits level with guard lip.
I know on Youtube there is a 4 part video clip explaining lowering and Im sure its for the front and not just the rear. Have a search anyway.
1971 Type 3 Fasty - EJ20T
I love 242HP sleepers.
How many sets of lights does it take a $229k Carrera S to learn?
UPDATE: Cayman S, M3, B4 now added to the list.
Volkswagenboy
Threads: 92
Mood: Indifferent
| posted on April 23rd, 2008 at 11:46 PM |
Yeah, there's a two part instruction for the front as well as a four part instruction for the rear on youtube.
The front end literally takes around 20 minutes if you know your way around a toolbox.
If you need any further help after the vids there's plenty of people here to guide you.
-Staggers.
shaihulud
Threads: 197
| posted on May 2nd, 2008 at 02:49 AM |
If only one torsion bar was adjusted would it have the effect of softening the front without lowering it much, if any?
vw54
| posted on May 2nd, 2008 at 06:36 AM |
I would be replacing the rubber bushes in the rear end as well and while yr there lower it properly
