[ Total Views: 1650 | Total Replies: 6 | Thread Id: 70611 ]
Author: Subject:  Drop spindles - will these fit a 71 type 3 bj?
Membersinecure
A.k.a.: Sin
Want another... :(
posted on July 21st, 2008 at 03:19 PM
http://cgi.ebay.com.au/VW-VOLKSWAGEN-BEETLE-DROP-STUB-AXLES-EMPI-RAT-ROD-LOOK...
If they don't fit, why? Can they be modified to fit easily?
A POSSE AD ESSE.
Membermackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off :td:
posted on July 21st, 2008 at 05:39 PM
No and no they can't be modified to fit. The only dropped spindles I have seen for the type 3 are these. http://www.thesamba.com/vw/forum/viewtopic.php?t=244520
http://images.thesamba.com/vw/gallery/pix/459040.jpg
http://images.thesamba.com/vw/gallery/pix/421376.jpg
Quote of the week
Membersinecure
A.k.a.: Sin
Want another... :(
posted on July 21st, 2008 at 07:39 PM
Thanks, may have to check if those will be legal over here. A$780 is a bit steep though.
A POSSE AD ESSE.
Membermackaymanx
A.k.a.: Brent
Threads: 97
posted on July 21st, 2008 at 08:22 PM
The only other option I have seen is mounting a type 1 beam up to the type 3 frame head (usually done to run narrowed beams). Only way to get those drop spindles legal would be to buy 2 set, let your engineer test 1 set to destruction and use the other set.
Quote of the week
Membersinecure
A.k.a.: Sin
Want another... :(
posted on July 22nd, 2008 at 11:13 AM
I take it that swapping beams isn't as easy as it sounds.
A POSSE AD ESSE.
Membermackaymanx
A.k.a.: Brent
Threads: 97
posted on July 22nd, 2008 at 11:49 AM
http://www.thesamba.com/vw/forum/viewtopic.php?t=305529&postdays=0&po...
http://www.thesamba.com/vw/forum/viewtopic.php?t=301887&highlight=type++beam
Quote of the week
Membersinecure
A.k.a.: Sin
Want another... :(
posted on July 22nd, 2008 at 04:02 PM
Thanks for all the info. Found another story with some good pics:
http://www.kustomcoachwerks.com/forums/viewtopic.php?t=2627
I'm not sure chopping the bottom off the front frame horn is something I would undertake as a novice. I guess I'll just keep wrecking bump stops!
A POSSE AD ESSE.
[ Queries: 40 ] [ PHP: 16.1% - SQL: 83.9% ]
