| [ Total Views: 2224 | Total Replies: 4 | Thread Id: 72513 ] |
GutsBus
Threads: 2
| posted on October 25th, 2008 at 06:05 PM |
T3 Caravelle Buzzer
Hi All,
I was wondering if someone out there can help?
I have a T3 Caravelle which has a buzzer located in the dash that goes off when I am slowing down, the oil light also flashes. To stop the buzzer I
either have to speed up or slow down further, and put my foot on the clutch and pump the accelerator a couple of times.
I would really appreciate any help.
Thanks |
syncropro
| posted on October 25th, 2008 at 07:02 PM |
Low oil pressure - check oil level.
Bizarre
| posted on October 26th, 2008 at 09:28 AM |
"could" be the switch
But...........................
GO here
http://www.brick-yard.co.uk/forum/default.asp
Do a search under "buzzer"..................(or buzzer of doom )
Do you have a wiring diagram??
Pretty sure there is 2 switches
grumble
Mood: happy all the time
| posted on October 26th, 2008 at 08:59 PM |
There are 2 switches,one between the pushrod tubes on no3 & 4 cylinders and 1 below the crank pulley near the water pump,we usually replace both
as they are a bugger to get to. regard Les
GutsBus
Threads: 2
| posted on November 3rd, 2008 at 09:00 PM |
syncropro - Sorry, should have mentioned the oil level was ok.
Bizarre - Thanks for the site, it's a good one.
grumble - Thanks for the tip. Changed the switch near the pushrod tubes on no3 & 4 cylinders as it was an after market one. The buzzer is a lot
better, but still goes off at a lower speed. I'll change the other one and check the wiring as they suggest in a post from the link Bizarre gave me. |
