| [ Total Views: 841 | Total Replies: 3 | Thread Id: 72960 ] |
grogy
Threads: 344
| posted on November 18th, 2008 at 12:55 PM |
091/002. hfgs ?s on bulletproof trans
hi, if a 091 trans is used, a spacer plate of 8mm is needed with the intermediate housing, is this correct? then both trans are the same
length......... ? who makes the spacers? is the spacer the same as the strenghening plate, if not is the strenghtening plate required regardless?
sorry to sound such a novice, but thats why im always asking. thanks
dangerous
Mood: 591
| posted on November 18th, 2008 at 09:23 PM |
I am not sure if anyone makes a comercially available spacer in 8mm.
The few I have seen were a specially made one-off item.
It is used because the 091 intermediate housing from the factory is thicker than the 002 because of the 091's wider gears.
I am not aware of anyone making the type1nose cone conversion yet for the 091(only 002).
The main reason for a "strengthening plate" on that end would be the mount,
but a steel plate sandwiched between the main case and bellhousing may be worth doing in an off-road race situation.
posted by westi
That's mad Alan.
grogy
Threads: 344
| posted on November 18th, 2008 at 10:08 PM |
thanks dave, it seems nothing is ever just straight forward
HGFS
A.k.a.: Greg
Threads: 42
Theme: UltimaBB Pro Brown
Mood: OK, I guess?
| posted on November 19th, 2008 at 12:44 AM |
posted by dangerous
Damn, that could be a problem, I didn't realise that. I just thought that the 091 was stronger hence the one to go for, didn't know the 091
couldn't have the T1 shift setup.
So many things to get right......
1954 Oval long term project going nowhere
1958 Beetle drag car project
1959 Beetle project I need to sell one day
1969 Squareback
