[ Total Views: 1320 | Total Replies: 3 | Thread Id: 73757 ]
Author: Subject:  Removing a known Beetle rust trap
posted on January 1st, 2009 at 10:57 PM
Some vandalism occurred to my daily driver/sons car just before Christmas, so now its time for a bit of a tidy up. Somebody jumped on the roof and bonnet.
I removed the bottom of the A pillar, this is a very bad spot for rust as the drain hole often blocks up with crud, it didn't actually have any rust in this area.
http://www.clubvw.org.au/images/rust%20trap.jpg
MemberSTIDUB
Over it.
Threads: 57
posted on January 1st, 2009 at 11:10 PM
so your saying because you left it open it hasnt rusted or when you cut it open there was suprisingly no rust? i cant tell if your stating a fact or what but im curious all the same
posted on January 1st, 2009 at 11:44 PM
A lot of bugs rust in that area because the crud cant get away. VW had about 10mm hole in that area but it soon filled up.
I do it as a preventative, my daily is surprisingly rust free, it did have rust treatment when it was new as it had a sticker on the window and has plastic plus where stuff has been squirted in.
MemberSTIDUB
Over it.
Threads: 57
posted on January 1st, 2009 at 11:57 PM
ok now i follow, any issue with much water getting into other bits of the body? say up thru the hole then down thru the sills or onto the floor where the loom comes down around there? that would be my only concern...
[ Queries: 40 ] [ PHP: 11.3% - SQL: 88.7% ]
