| [ Total Views: 678 | Total Replies: 6 | Thread Id: 7440 ] |
Starbug
rustbag
Threads: 148
| posted on June 12th, 2003 at 11:55 PM |
stupid nuts!!
anyone have any special tricks to getting the breather nut out of the oil well/generator stand? As far as i can see it should just screw out with a
little bit of tricky improvisation (and much ruining of kitchen tools)... But it wont budge. At All!
:cry
any suggestions, alterations or well directed curses are much appreciated! |
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on June 13th, 2003 at 01:10 AM |
Try harder?
Kruizin Kol
lugnuts
A.k.a.: Mike
Threads: 88
Mood: semi-retiring
| posted on June 13th, 2003 at 04:55 AM |
Try some garage tools,you talking about the breather gland nut?Grab the oil filler assembly with two hands and twist to break the rust sealing it
together,then you have to make a tool to fit inside the filler,as big as you can for leverage,stick a torch down the neck yule see what i mean,good
luck.Mick:P |
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on June 13th, 2003 at 08:38 AM |
any VW shop should carry the special tool for doing the job, if you can take it to a vw shop you could get them to loosen it.
Brad
Threads: 332
Mood: Manx Buggy Building
| posted on June 13th, 2003 at 10:18 AM |
Special Tool WTF
Here is a secret hint but keep it under your hat. Go and get a mower blade for a victa, they fit in the slots just nice and then use shifter to turn
it .
If you like, I can buy a set for $5 open the packet, kick it around the yard, wrap it up and put a VW Special tool label on it and sell it to you for
$20 if you like, probably even have a VW stamp kicking around so I could stamp it and all.
Maybe I can sell one to Wes .... hey Wes want to buy a special tool ???
Starbug
rustbag
Threads: 148
| posted on June 13th, 2003 at 03:03 PM |
Thanks guys after trying mower blades, screw drivers and hammers and also
cutting up my nice bottle opener (which fit perfectly but did absolutely squat...)
ive decided to invest in a new one.:thumb |
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on June 13th, 2003 at 03:55 PM |
look at the first tool on this page, and you'll see something dodgy for the job
http://www.thebugshop.org/bsntt.htm
as well as other homemade special tools.
The real special tool looks like this.
| Error |
amazer
kombi pilot
Threads: 308
Mood: Peachy!
| posted on June 13th, 2003 at 05:21 PM |
WOW! I have finally found someone who is worse with a brazing rod than what I am! Yee haa.
Brad
Threads: 332
| posted on June 13th, 2003 at 09:31 PM |
WTF
posted by Starbuggy
WTF mower blades failed :cry:cry
Don't beleive it , you are welcome to borrow my blades ..
