[ Total Views: 857 | Total Replies: 9 | Thread Id: 75026 ]
Author: Subject:  L beetle to 1962 engine and gearbox swap
Membermax1962
Threads: 3
posted on March 1st, 2009 at 11:48 AM
has any one done an engine and trans swap from L beetle to a type 1 1962 sedan ? if so is there any modification required to fit he later 1600 twin port and trans. The code on the motor is AD cheers,max
question.gif posted on March 1st, 2009 at 01:12 PM
the only thing I know is the gearbox and rear suspension on an L beetle is IRS with CV Joints...
the 1962 beetle had swing rear axles ..
so they are NOT interchangeable...
Many beetles - all years - have 1600 engines fitted...
You could just bolt in the 1600 engine...
but the 12 volt clutch is 200mm where as the 6 volt clutch is 180mm
this has been done many times....
posted on March 1st, 2009 at 03:24 PM
most ppl just machine the old 6v flywheels to bolt upto the 1600 engine
saves frigging around changing clutches, starters, clearance bellhousing etc
Membermax1962
Threads: 3
posted on March 1st, 2009 at 05:44 PM
I have the trans and engine just wondering if it's a straight forward swap ie bolt in etc
MemberBoozo
Back in the bug
Threads: 34
Mood: cruisy
posted on March 1st, 2009 at 05:55 PM
no its not unfortunately, the rear suspension is very different so the gearbox wont go straight in. it requires a conversion
[size=4] '59 or Kombi?....feeling confused [/size]
'59 bug
'68 bug
'82 import T3 BUS. aircooled
Membermax1962
Threads: 3
posted on March 1st, 2009 at 08:17 PM
has anyone attempted this, is it event worth it or should I be looking at modifying the flywheel and starter to match the old gear box? any suggestions ?
posted on March 1st, 2009 at 08:45 PM
It is easier to change the pans over
But a L bug pan wont fit a 62
you need a converted 69 semi auto pan or a 1976 pan
The L bug has an IRS gear box and the 62 a swing axle
2 entirley different thiings
question.gif posted on March 2nd, 2009 at 12:43 AM
You could bolt the original gearbox to the 1600 engine..
I believe that may be fairly straight forward..
Membermax1962
Threads: 3
posted on March 3rd, 2009 at 05:43 PM
ok, what's the best gearbox for highway that's will work well with the 1600 and that will fit into the 62 with out major mods?
posted on March 3rd, 2009 at 08:49 PM
1500 swinger :tu:
1600s love the 4.125 boxes
[ Queries: 40 ] [ PHP: 13.1% - SQL: 86.9% ]
