[ Total Views: 568 | Total Replies: 7 | Thread Id: 7681 ]
Author: Subject: Porsche style fans
Memberwombatone
A.k.a.: Michael
Threads: 41
Mood: Ready to race
posted on June 21st, 2003 at 09:26 AM
Porsche style fans
I’m thing of using a Porsche style fan on my 1600 buggy to improve the air flow to the heads. Is anyone else running this set up? Is there much improvement over standard set up? Do you have problems with it? What do you think about them?
MemberChe Castro
ankle straps
Threads: 79
Mood: (( }:-{D]
posted on June 21st, 2003 at 01:29 PM
is the engine a 1600 ??? a porsche fan shroud is unecessary for anything short of a huge turbo motor. the stock doghouse can handle up to about 2.3L size kinda heat
Jon
posted on June 21st, 2003 at 07:55 PM
I agree - they are good for BIG motors but not a 1600
You can get a 11? and 5 blade fan - maybe if you REALLY wanted the "look" a 5 blder will not over cool.
No shroud cools as well as a VW shroud
MemberRobo
Threads: 120
Mood: Oval madness
posted on June 22nd, 2003 at 07:28 AM
Check out this site if you are serious, he has very good kits and has a good name overseas as well, one of the best!
http://www.sharpbuilt.com.au/
Rob.....
Boxer Power
posted on June 22nd, 2003 at 08:34 AM
The kits arearound $1200 or so last time i checked.
The Porsche Alternaoyer is the expensive bit, If you can find one, as the Porsche guys dont like selling them to VW people for some reason.
Memberwombatone
A.k.a.: Michael
Threads: 41
Mood: Ready to race
posted on June 22nd, 2003 at 09:51 AM
it is just for a 1600, but a buggy which seems to run a bit hot. thought a Porsche style fan mite make it run cooler.
Membergraham
Mood: good
posted on June 22nd, 2003 at 05:12 PM
FANS
everyone I know that has a buggy is running a doghouse including blokes with type 4 motors mind you they are running external oil coolers but do agree with everyone else it is an unnecessary expense.
extreme dubber
Memberwombatone
A.k.a.: Michael
Threads: 41
Mood: Ready to race
posted on June 22nd, 2003 at 08:52 PM
Thanks for the advice I probably should look at an external oil cooler first. Where do they mount then out off harms way on a buggy?
MemberKruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
posted on June 22nd, 2003 at 09:00 PM
Have you flushed out the existing cooler and checked that the cooling fins on the motor are all clean? It could be that you can get it cooling properly without spending heaps of money. It's worth checking first anyway. :)
Kruizin Kol
