[ Total Views: 2259 | Total Replies: 11 | Thread Id: 76974 ]
Author: Subject:  Boof's wrx bug finally back on the road.
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on June 4th, 2009 at 09:16 AM
After a 2 year body swap and numerous final improvements the bug is back as my daily driver.
Still has old motor in it with about 220hp at the wheels. I didnt want to run full boost as the motor is getting on. New forged piston 2002 motor will be done in a month or so....did someone say 70hp NOS kit and 25 pounds of boost?
Now has Nissan silvia radiator( works too well had to block most of it off), custom alloy tank, improved air intake, improved exhaust, still running air to air intercooler which is even colder now with bigger rear gaurd scoops...and most importantly a nice rebuilt box thanks to Dave Butler.
Am driving it from Pennant Hills area to Bondi Junction every day so i hope to see a few of you guys about.
Matt
posted on June 4th, 2009 at 10:16 AM
Thought you'd disappeared Matt. Good to see this still belting around the local neighbourhood.
Memberttriebler
Threads: 16
posted on June 4th, 2009 at 10:30 AM
Geez I'll be keeping well clear of this thing at any set of lights!! Matt how about some pix of the work done to it
Reversed gears for Subaru transmissions.
Fit a Subaru 5 speed to your rear engined car
www.subarugears.com
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on June 4th, 2009 at 07:20 PM
Ill take some pics and post them in the next few days.
Just spent the day modifying the carpet kit i got to cover the relocated 2 piece firewall and around the different seat mounting points. I also had some dynomat extreme that i stuck in the rear of the car.
Between the engine and the albins gears, it is alot more pleasant to drive with some interior to soften the noise.
Looks like I will need some new tires as the current ones have sat for so long, although 80% tread, and have gone a bit hard. You can just feel it breaking traction ever so slightly through second and third under boost.
I just need to find someone to run it at the creek for me one Wed to see how it goes. At 135kg's there is a good 55kg of excess weight to strip just from changing drivers.
Will keep you posted....
Matt
Member555bug
WRX Bug Boy
Threads: 79
Theme: UltimaBB Vintage
Mood: turbo charged
posted on June 4th, 2009 at 07:48 PM
are you going to bring it to Warwick this year? I'd like to pick your brain about some items left on my project.
Stephen
http://members.optusnet.com.au/s0411400342/555bug.jpg
Memberrose
doin it for d girls
Threads: 308
Theme: UltimaBB Pro Red
Mood: always happy
posted on June 4th, 2009 at 07:52 PM
Matt
I could drive it, I am only 49kg s:crazy::crazy:
[img][/img]
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on June 4th, 2009 at 10:07 PM
I would like to make the trip, and have the new engine finished to make it worth the run.
Rose is the lowest bidder so far:smilegrin:
MemberJack Burton
Threads: 4
posted on June 4th, 2009 at 10:28 PM
Boof took me for a spin the other day...one minute we are cruising along, the next i am looking at the headliner withing for the seat to tear off the floor pan.
I am 135kg as well... SICK
You know what Jack Burton always says....its all in the reflexes.
MemberBaja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
posted on June 4th, 2009 at 10:46 PM
I'm 57kg, and have drag racing experience (albiet on a motorcycle). :)
Membertrickysimon
A.k.a.: Simon Azzopardi
Threads: 43
posted on June 4th, 2009 at 10:50 PM
Dam, I guess 82kg is too heavy then.
I will drive it like a P plater if that helps :lol:
Memberseagull
Threads: 752
posted on June 5th, 2009 at 12:40 AM
Matt
25 PSI Hey Matt !
WOW , some side ways action with that power. What con rods are you using ?
Membergerrelt
Threads: 3
posted on June 5th, 2009 at 04:12 AM
What a great car!!! :tu: :)
Do you have more pictures? Engine, radiator setup etc.
[ Queries: 40 ] [ PHP: 12.4% - SQL: 87.6% ]
