[ Total Views: 924 | Total Replies: 13 | Thread Id: 76997 ]
Author: Subject:  i cant get my fuel tank out...advice?
Memberisky
Threads: 40
Mood: awesome....
posted on June 5th, 2009 at 10:14 AM
Hi all,
Im trying to get my fuel tank out of my 1960 Karmann so i can flush it but there's this painful arm that connects it to the car. The arm is held to the tank by a pin that is near impossible to get off. Even if i do get it off i doubt ill get it back on. I thought of undoing the fuel valve nut all together but it's so hard to turn im scared im going to round it out....Any suggestions?
Ive already put a little tear in the fabric line that runs from the tank to the copper hose that goes to the engine but that's no prob seeing i was going to replace it any ways....
Gees the Bugme video looked so simple, but they never had this bloody arm holding it to the car i guess (it looks as though it has no purpose anyway)....
any advice would be appreciated. Do i even have to take the tank out to flush it?
my Karman looks worse than my avatar....seriously!
...but i love it more than words can say
1960 Karmann Ghia
1961 Karmann Ghia
1975 Bug
1998 Transporter LWB
1992 Nissan Maxima
http://www.iskyC96.com  (awesome corsets ;))
http://www.moonstarmagic.com
Membervwsteve
A.k.a.: steve
karmann crazy
Threads: 200
Mood: Busy!
posted on June 5th, 2009 at 10:27 AM
it is normally a split pin holding the fuel tap in from memory, otherwise undo the hose and pull the tank slowly up with the tap conected and it should pull though the hole, it may bend a little but you can straighten it and then undo it when its out
1 1963 356b porsche coupe
2 1960 karmann ghia cab
1 1965 karmann ghia cab
1 1966 karmann cab
1 1961 split ute
1 1967 split p/van
1 1952 standard bug
1 1963 ragtop
1 1960 ragtop
2 1954 ovals
1 1956 oval baja project
1 1957 oval flying flea
Memberisky
Threads: 40
Mood: awesome....
posted on June 5th, 2009 at 10:33 AM
thanks rexy...
yep it is a split pin. I never tried to pull the tank up to see if the pin would come out on its own. Been looking at this http://www.vw-resource.com/fuel_tank.html  but it's never as easy as they make out. Besides i think they're some how releasing it from under the car which i cant see how...Ill give it a shot...
1960 Karmann Ghia
1961 Karmann Ghia
1975 Bug
1992 Nissan Maxima
Memberbushed
Threads: 66
posted on June 5th, 2009 at 10:34 AM
take it out to flush.
the pin can be cut and later replaced with a newby.
the arm is your recerve tank lever,,,note the position so u dont put it back upside down.
replace the fuel line so a tear in it tells me.
maybe if u take one front wheel off u can access the pin better.
Scirocco mtrs is nr u, the lad had a show ghia like no others. the dad is a vw specialist if u need a kgmate wid rebuild knowhow and passion.
Memberisky
Threads: 40
Mood: awesome....
posted on June 5th, 2009 at 10:38 AM
oh hang on.... are you saying the tap connecting to the car should pull out of the hole where its connected to the car? then take the pin out after its free?
1960 Karmann Ghia
1961 Karmann Ghia
1975 Bug
1992 Nissan Maxima
Membervwsteve
A.k.a.: steve
karmann crazy
Threads: 200
Mood: Busy!
posted on June 5th, 2009 at 10:40 AM
yep, its a rough way of doing it but better than destroying the fuel tap, they are becoming scarce, watch you dont split where it screws to the tank
1 1966 karmann cab
1 1961 split ute
1 1967 split p/van
1 1952 standard bug
1 1963 ragtop
1 1960 ragtop
2 1954 ovals
Memberisky
Threads: 40
Mood: awesome....
posted on June 5th, 2009 at 10:42 AM
thanks bushed ill try that...yeah id kill to have a Karmann buddy with passion in my neck of the woods :)
1960 Karmann Ghia
1961 Karmann Ghia
1975 Bug
1992 Nissan Maxima
Memberisky
Threads: 40
Mood: awesome....
posted on June 5th, 2009 at 10:44 AM
cheers Rexy...scares me a little but its an option. Thanks mate
1960 Karmann Ghia
1961 Karmann Ghia
1975 Bug
1992 Nissan Maxima
Memberbushed
Threads: 66
posted on June 5th, 2009 at 10:50 AM
think of the angle of the tap when u pull on the tank...it should be smilar ......spray some wd40 /crc etc on the inside of car lever bit.
Great to meet u at last Steve, thanx for tha tour
talk soon
B
Memberisky
Threads: 40
Mood: awesome....
posted on June 5th, 2009 at 10:57 AM
Hey guys...
GOT IT!!
i just cut the pin in the end with these hardened pliers used to cut steel boning for womens corsetry....Yup you guessed it, i make steel boned corsets for a living. So glad this girly trade has finally come in handy for some real mans work ;)
So is the idea of putting washed gravel in the tank and thrashing it about to loosen rust for real? Is that the way to flush and clean a tank?
Thanks again
Anthony
1960 Karmann Ghia
1961 Karmann Ghia
1975 Bug
1992 Nissan Maxima
Memberbushed
Threads: 66
posted on June 5th, 2009 at 11:06 AM
nevva hoid that and would only use fine stuff caus the tap end also has a fine gauze cylinder shaped brass filter and it could break due to age etc
clean and dry it pref wid compressed air and shne a torch inside to check anny flaking check outside for rust bubbles.
DONT use a match or lighter hay!!!
Memberisky
Threads: 40
Mood: awesome....
posted on June 5th, 2009 at 11:29 AM
lol! thanks Bushed *he says while typing on his keyboard with lighter in hand zeroing into tank. Compressed air sounds the go...Time to find a mate with a compressor...
1960 Karmann Ghia
1961 Karmann Ghia
1975 Bug
1992 Nissan Maxima
Membercolonel mustard
Threads: 51
posted on June 5th, 2009 at 11:44 AM
brake sucker to empty. wash with something before using compressed air... can be a bit dangerous.
Memberisky
Threads: 40
Mood: awesome....
posted on June 5th, 2009 at 11:55 AM
colonel mustard ...thanks mate,
i siphoned it earlier. Just use water to rince? My gasket between my tank gauge reader and tank broke from age. Can i find these around here any where or do i need to order them online?
1960 Karmann Ghia
1961 Karmann Ghia
1975 Bug
1992 Nissan Maxima
[ Queries: 40 ] [ PHP: 4.0% - SQL: 96.0% ]
