[ Total Views: 926 | Total Replies: 7 | Thread Id: 79499 ]
Author: Subject:  Shock mounts rear
MemberKuchster
A.k.a.: Robert Kuch
Threads: 182
posted on October 7th, 2009 at 07:04 PM
Shock mounts rear
When converting oval pan to later model rear end, box and tubes and hubs, what do you do about the shock mounts?
I understand that the oval mount sits vertical and where it bolts on is straight, where as the later model pans and hubs bolt on at an angle.
Who has done the conversion and knows about this?
Kuch's Laser Cut Products
http://www.kuch.com.au/laser
posted on October 7th, 2009 at 09:46 PM
It's not a problem at all, shock body turns on shaft so no alignment issue.
MemberVWCOOL
Threads: 235
Mood: happy to help
posted on October 8th, 2009 at 07:06 AM
I think you will find the trailing arms foul on the chassis
Pay your debts, CxxT
posted on October 8th, 2009 at 08:28 AM
What trailing arms??? Do you mean spring plates? If so no they wont be a problem. If you mean Diagonal trailing arms, well he never said he was fitting IRS, just later model "box, tubes and hubs".
MemberKuchster
A.k.a.: Robert Kuch
Threads: 182
posted on October 25th, 2009 at 07:11 PM
Yeah not going IRS,
Another question is, for the springplates, the torsion bar covers, i have the covers with the cutouts, yet the floorpan is a round smooth donut, is it ok to use round donut inner rubber, and the knobbly outer rubbers? Or should they be matching?
posted on October 25th, 2009 at 07:16 PM
No problem to have the mix. Some models are exactly that stock. Just order the correct size inside hole depending where used.
MemberKuchster
A.k.a.: Robert Kuch
Threads: 182
posted on October 25th, 2009 at 07:19 PM
Going over to georges soon, so i'll take that point of measuring the hole before i go down.
Cheers for the help :D
posted on October 26th, 2009 at 12:36 AM
Yes,
I've seen that some use the inner on one side as the outer on the other...
[ Queries: 40 ] [ PHP: 15.0% - SQL: 85.0% ]
