[ Total Views: 966 | Total Replies: 9 | Thread Id: 79773 ]
Author: Subject:  Head Beam Problem with Super Bug 1973
Memberwolf99
Threads: 8
exclamation.gif posted on October 21st, 2009 at 07:33 PM
Hello, everyone.
My model is 1973 Super bug. I'm having problem with lighting system.
At Head light bottom on righth hand side, You can press it two steps for low beam and high beam.
When I press to low beam every lights are fine( Head light, rear light and light on speedometer) but I turn down to high light rear lights and light on speedometer don't work(off).
My questions are which part of electrical system in my bug is broken or doesn't work?
And can I fix it by myself (hard to do it by myself or not)?
I just call a volkswagen shop which is closest with my home. I can bring my car to them on Saturday. They have machnice on Mon-Friday only.
Thank you very much
Membercolonel mustard
Threads: 51
posted on October 21st, 2009 at 08:10 PM
Sorry mate, I don't understand your question.
Memberpod
A.k.a.: paul mrvw061
Mood: could be better
posted on October 21st, 2009 at 08:21 PM
well what i can decipher is... when on low beam all lights on,then when he flicks to high beam the speedo and taillights go out:?:
check wbsite for location
All Welcome
http://www.flatfour.org/
posted on October 21st, 2009 at 08:59 PM
sounds more to me like they're talking about the headlight rocker switch that Lbugs have on the right hand side of the dash
Memberwolf99
Threads: 8
posted on October 21st, 2009 at 09:05 PM
Yes, that's right.
Memberwolf99
Threads: 8
posted on October 21st, 2009 at 09:08 PM
Yes, you're also right.
Thank you all for answer my question. I'm a Thai thay why my English is not good.
posted on October 21st, 2009 at 09:13 PM
If it is a 73 bug the 2 step switch is parkers and low beam
High beam is activated by flicking the indicator lever
Is the "blue" light on, on the dash??
It "could" be a bad earth
Important question - has it EVER worked??
Is this a new problem or has it always been a problem??
It could also be the switch itself
Pretty sure there are a couple of different types
Some one may have put a wrong one in and cooked it??
Unless you have some idea of electrics i would leave it for some one who does
Memberwolf99
Threads: 8
posted on October 21st, 2009 at 10:45 PM
Thank you
Yes, blue light still on( in speeddometer)
It has been worked so it was new problem last week.
How can I solve this problem????
posted on October 22nd, 2009 at 07:54 AM
There are 2 screws in the front that earth the head lights.
One in the red circle - one on the other side.
make sure these are biting nicely - may be put a star/claw washer under neath
Give the indicator swith a pull towards you (a little tap??) so as the blue light goes off and see what the lights are like then
Memberwolf99
Threads: 8
posted on October 22nd, 2009 at 02:58 PM
Thank you so much
[ Queries: 40 ] [ PHP: 12.7% - SQL: 87.3% ]
