| [ Total Views: 815 | Total Replies: 9 | Thread Id: 81623 ] |
kenno28
Threads: 12
| posted on January 26th, 2010 at 09:02 AM |
Body Off Restore
Starting to undertake a body off restore.
Have a question:
I will be replacing the heater channels, so how do I make sure that the holes all align up (bolts though floor into heater channel) when the new
channels are installed.
Floor will also be replaced.
I will be bracing door area etc, so to ensure no sagging.
Is it a matter of making up some form of width jig, one heater channel to another?
Any comments/help in this area would be great.
ian.mezz
Threads: 280
| posted on January 26th, 2010 at 09:44 AM |
if you doing a complete resto make sure you have a spare $30,000
good luck
I seen a jig on this link
http://forums.aussieveedubbers.com/viewtopic.php?tid=75753
57 oval
Oval type 4 Fuel Injected
Threads: 48
Mood: Oval
| posted on January 26th, 2010 at 11:17 AM |
http://www.ramva.org/dragenwagen/heaterchannel.html
Have a look at the above link may be of some assistance to you replacing your heater channels
kenno28
Threads: 12
| posted on January 26th, 2010 at 12:19 PM |
Thanks for that, shall save and study the document.
If money was an issue I would not be doing it, finding the time is the problem.
ian.mezz
Threads: 280
| posted on January 26th, 2010 at 02:26 PM |
If you dont have any time
buy this one all the work has been done .
http://aussieveedubbers.com/viewtopic.php?tid=67295
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
| posted on January 26th, 2010 at 03:32 PM |
Anything can be done with money or resources. Money buys resources (including time)
Mick058
| posted on January 27th, 2010 at 05:49 AM |
Thanks for the plug Ian
30k would be on the conservative side too...without conversion
Camo
A.k.a.: Kev
Threads: 209
| posted on January 27th, 2010 at 08:51 AM |
posted by ian.mezz
How true. And extra for the WRX motor as in Mick058 case.
But to answer your question, the thread holes within the heater channel should be in the same positions as the original (I say should). Just double
check before you remove a section and replace it with the same replacement section. And take some measurements from a point on the car to the first
hole as an example.
You can go to this site and get the DVD on heater channel replacement. I already have it and a couple of others. Here is the link http://bugmevideo.com/
Good luck, Kevin
kenno28
Threads: 12
| posted on January 27th, 2010 at 09:06 AM |
Thanks for the information posted in regards to heater channel replacement.
71dub
Threads: 46
Mood: happy
| posted on January 28th, 2010 at 04:10 PM |
i bought the bug me cd on heater channel replacement found very helpful .worth watching a couple times to see how it is done .
