[ Total Views: 1995 | Total Replies: 10 | Thread Id: 84558 ]
Author: Subject:  Beetle Rust Repair Sections
MemberCJ_DT
posted on June 29th, 2010 at 09:06 PM
Hello,
New to this whole beetle thing, is there a supplier anywhere who sells a rust repair panel for the lower windscreen corners or the whole panel which the wipers come through. Its a 67 so the earlier style panel, havent been able to find a rust free one in lots of wrecker searching.
Coming at this fom Minis, wher eyou can get enough new panels to make a whole new shell, surely someone does this for beetles also?
Cheers Chris
posted on June 30th, 2010 at 07:57 AM
Talk to Vintage in Sydney 02-9789-1777
Memberchristopher
Threads: 18
Theme: UltimaBB Psyche Green
posted on June 30th, 2010 at 02:49 PM
Talk to Classic Veedub there cheap for Brazilian parts
I'd rather die trying, than not have tried at all.
MemberAyeBee
Threads: 18
posted on July 1st, 2010 at 04:37 PM
Hey Chris, there's a guy here in the northern suburbs (actually I think he might be in Gawler), who will make rust repair sections for any car, any make. Comes to your house, measures whatever section you want replaced, and custom makes it.
Quality of his work from what I've seen is very good (made a mate a set of 4 mudguards for his 1932 Ford Tudor hot rod) for an excellent price. Happy to grab his details from my mate tonight if you're interested.
MemberCJ_DT
posted on July 1st, 2010 at 09:25 PM
AyeBee that would be aweseome, beause it doesnt appear to be a commercially available part.
Cheers Chris
MemberAyeBee
Threads: 18
posted on July 2nd, 2010 at 06:10 PM
Sorry for the late reply Chris, the guy's name is Shane Dale, and his email is:
csdale@adam.com.au
I've got a phone number for him too if you need it. My mate seems to think he's from Gawler as well. Nice and local for you.
Regards,
Andy
Membergazzac
Threads: 42
posted on July 3rd, 2010 at 11:04 PM
CJ_DT I am in need of the same panel,(passanger side) mine is a 67 aswell.if you get one made can you post the outcome. I would be very interested geting him to make me one too. Cheers Gary
gulf blue1966 Beetle,1500 manual.
MemberCJ_DT
posted on July 4th, 2010 at 06:15 PM
Thanks Andy,
I have emailed Shane and will see how it all goes, and Gary I will post some pics of the results if it all comes together.
Chris
MemberSlammed59
Threads: 3
posted on July 5th, 2010 at 08:48 PM
give mick motors a call, we just bourt a hetaer channel (dansk) quarter panel and two battery sections off him. good proces aswell!
MemberCJ_DT
posted on July 18th, 2010 at 11:23 AM
Hello, Thought Id let you know how it all turned out. Was unable to get a commercially available piece to weld in, so had Shane (mentioned above) make me the rust repair panel.
Very reasonable price, and very good job (I had him do it near enough is good enough as opposed to a file finish type job and it was damn near perfect)
First thing was to pop the windscreen out, which with the old solid seal wasnt that easy, ended up cutting the rubber to stop me smashing the screen. That reavealed the extent of the rust, bad on the drivers side, pretty good on the passenger side.
Rust on the driver side;
http://img291.imageshack.us/img291/7288/ernierust002.jpg
http://img821.imageshack.us/img821/4457/ernierust001.jpg
[/img]
Patch panel in place to trace around so I dont end up with a hole bigger than the panel;
http://img641.imageshack.us/img641/1560/ernierust003.jpg
Started by cutting out all the rusty metal. Removed all the rust and back to solid steel;
http://img375.imageshack.us/img375/7796/ernierust006.jpg
http://img199.imageshack.us/img199/6198/ernierust007.jpg
Straighten the screen lip I bent being too over eager removing the spot welded lip
[img]http://img269.imageshack.us/img269/11/ernierust010.jpg
Trial fit, then remove all paint near where ill be welding;
http://img341.imageshack.us/img341/3076/ernierust008.jpg
http://img443.imageshack.us/img443/7368/ernierust012.jpg
Drill some holes in the lip for some plug welds;
http://img143.imageshack.us/img143/7501/ernierust011.jpg
Tack weld it in, then slowly work my way around. The gap on the middle end is wayy more than I wanted, and I distorted the panel in the middle ever so slightly on the welding when I blew a hole and welded it up. That said it tapped back to just about perfect, and will only need a tiny skim of bog.
http://img35.imageshack.us/img35/566/ernierust013.jpg
http://img534.imageshack.us/img534/7708/ernierust014.jpg
http://img704.imageshack.us/img704/779/ernierust017.jpg
Overall I'm happy, not a body work person at the best of times, but it came out fine by my standards. And it no longer has a rust hole. Just got a few more to go.
So where is the best/cheapest place to get a set of seals for windscreen etc, and how does 67 aust model translate into the american models if I hit up ebay US?
Membergazzac
Threads: 42
posted on July 22nd, 2010 at 04:44 PM
Hello CJ_DT if you dont mind me asking what did he charge for that panel ? Cheers Gary
[ Queries: 40 ] [ PHP: 15.2% - SQL: 84.8% ]
