[ Total Views: 2067 | Total Replies: 2 | Thread Id: 8591 ]
Author: Subject: Installing 1969 Kombi wash/wipe switch 141955517
Memberkombi69
Threads: 34
posted on July 19th, 2003 at 01:41 PM
I've got a new 1969 Kombi wash/wipe switch 141955517 to install. A quick question. The two barbed hose connections are marked "B" and "D".
Which one is inflow, which one is outflow?
Thanks.
MemberKruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
posted on July 19th, 2003 at 05:55 PM
Hmmm, good question. I don't know the answer, but I'm not sure it matters either. I guess if the valve can't cope with pressure from the wrong side, then you'll notice leakage when you pressurise the washer bottle. In that case, try swapping them over.
Sorry I can't give you a definitive answer. :(
Kruizin Kol
MemberOld Dubber
Threads: 25
Mood: great!
posted on July 19th, 2003 at 08:12 PM
I'm fairly certain the reservoir is connected to "B"
Grahame
visit my club site at www.vwdcqinc.org.au
MemberPurple Martin
A.k.a.: Martin
Threads: 141
Mood: warm & fuzzy
posted on July 21st, 2003 at 08:56 AM
I don't know what your part is like, but for a typical washer motor the central hose comes from the reservoir and the side hose goes to the squirty nozzles.
Hook it up and try it - you'll soon find out if it's the right way round. ;)
1959 red & white Beetle
1975 Kombi camper
Membermodulus
A.k.a.: Peter Hill
Mood: modular
posted on July 21st, 2003 at 10:51 AM
I'm guessing here, so don't take it as gospel, but you might try:
Behaelter (reservoir, in German)
and
Durchlass (outlet or similar in German).
As has been pointed out, this is only important if the valve is only pressure-capable on one side.
HTH.
Peter Hill
1975 Type 2 Double Cab
modulus.com.au
